586,052 active members*
4,234 visitors online*
Thread: Usb Adapter
    Jul 2009
    5
    Usb Adapter
    Sorry if this is in the wrong section here.
    I was thinking of building a cnc milling machine and i was wondering would one of those usb adapters into parallel port work?
    My laptop dont have the actual parallel port only 2 usb ports.
    No
    Jul 2009
    5
    So Would an Expresscard adapter work? Or does it have to be completely straight into parallel?
    If it does need to be parallel whats a good solution to this no port problem?
    Feb 2007
    4553
    Post
    Nuzzget,
    This has worked for several members with notebooks.
    http://tinyurl.com/md4ynm
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2009
    4
    Νο usb adapter will work for cnc.
    Those adapters only provide a "fake" parallel port for printers.
    On the other hand, most pcmia cards will work.
    To verify the compatibility, go to the device manager and check the ports section. If it says usb printing service or something...it won't work.
  1. How do I fit a coolant adapter??
    By s1j1m10 in forum MetalWork Discussion
    Last Post: 05-25-2009, 11:07 AM
  2. PC-MPI ADAPTER
    By CHANDRU in forum CNC Machine Related Electronics
    Last Post: 12-14-2007, 12:06 PM
  3. need help with lathe adapter
    By Lionclaw in forum MetalWork Discussion
    Last Post: 01-03-2007, 02:02 PM
  4. 3/8 to 1/2 adapter
    By TMaster in forum Benchtop Machines
    Last Post: 07-29-2006, 12:15 PM
