what i want to do is make my z axis move the z axes a different amount.
ie: the gcode tells it to move say 1mm,
well the piece of stock that the part is to be cut from is 10mm thick,
so you can see what will happen.
is there a way to do that without editing the gcode or not
also how do i offset for useing different size cutting bit?
thanks in advance
