586,068 active members*
4,290 visitors online*
    12
    Blowing the fuses
    Hi, I just finished up building my 3 axis board and started testing it, however i blow the 3 amp fuse all the time. The first time I turn the sysytem on it works, but when i turn it on a second time the fuse blows instantaneously, i checked everything and can't seem to find a problem. Is the system suposed to be grounded somewhere? Any help greatly appreciated
    Jun 2004
    450
    I was having the same problem (my kit is no longer in use). What I found, is that if you toggle both switches at almost the same time, this will happen. When powering up, turn the fan switch on. Wait a few seconds, then turn the main switch on. When powering down, turn the main switch off. Wait a minute or so, then turn the fan switch off.
    May 2004
    198
    Quote Originally Posted by rocks101
    OK to use a 4A or 3.15 slo blo
    Dave Rigotti
  1. Series 2 BOSS 6 Axis motion problem
    By craig96us in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2006, 06:06 PM
  2. Motor tuning and Blowing fuses
    By DAB_Design in forum Gecko Drives
    Last Post: 11-02-2004, 02:10 AM
  3. Confused about fuses.
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 09-25-2004, 05:54 AM
