586,106 active members*
3,077 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Machining MOLD MAX HH
    Jul 2009
    23
    Cool Machining MOLD MAX HH
    Anyone had much experience with this type of material? I've been working with it for the last few days. Have also been working with a new tool in roughing of these parts. VERY, impressive.
    Jan 2007
    172
    been machining it for years.....turns fine with carbide, gotta watch high speed drills...tapping just sucks....but it makes good mold components that can last for years and years.
    Jul 2009
    23
    Yes drilling with high speed and tapping really sucks. Had an 7/16" x 8" deep hole to put in. Like the material wants to shrink around the tool as it heats up with the high speed. Went to a carbide drill with not one single problem. Tapping is out of the question so all needed threads were thread milled.
    Oct 2009
    10
    high speed steel drill sharpen just alittle off center this will make it cut a tad larger.
    also add neg relieve to the cutting edge this will prevent it from wanting to pull. due to the mat'l being gummy.
  1. Machining or casting mold cavity
    By Thorpydo in forum Moldmaking
    Last Post: 04-22-2009, 07:32 PM
  2. MIS CNC Machining and tooling - General machining - Thermoform Molds
    By modernprecision in forum Employment Opportunity
    Last Post: 11-24-2007, 05:05 AM
  3. Making a positive mold from a negative mold - how?
    By SRT Mike in forum Moldmaking
    Last Post: 03-29-2007, 10:30 PM
  4. Machining anodized parts or anodize after machining?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-12-2006, 06:22 AM
  5. uni-directional mold machining
    By HuFlungDung in forum DNC Problems and Solutions
    Last Post: 05-28-2003, 04:54 PM
