586,119 active members*
3,325 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > air compressor for a haas vf-2
    Aug 2009
    Question air compressor for a haas vf-2
    I was hoping someone could recommend an air compressor for a haas vf-2.
    Preferable quiet and at a decent price.
    Protomaker
    Nov 2007
    1702
    The minimum I'd use on a VF-2 is the two-stage Husky that they sell at Home Depot for about $850. That one is kinda' noisy but it's as cheap as you're going to get away with. You should also plan on buying the Harbor Freight refrigerated air dryer to go with it (about $350). So $1200 is entry level.
    After that, quiet costs money. How much you're willing to spend is how quiet you can have it.
    Greg
    Jul 2005
    12177
    For quiet you need to go rotary and the lowest cost I know about is a 3hp Chicago Pneumatic at about $3500 without a dryer.
    Jun 2006
    629
    Noisey isn't a problem. Just build an insulated and vented enclosure. We did for ours. It's got the green insulation on the inside, and has a bathroom vent sucking in Air and an exhaust vent at the other end!
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
  1. DIY air compressor
    By joecnc2006 in forum Hobby Discussion
    Last Post: 07-05-2014, 07:11 AM
  2. air compressor for a haas vf-2
    By protomaker in forum Want To Buy...Need help!
    Last Post: 08-06-2009, 04:14 PM
  3. New Compressor Help
    By 1ctoolfool in forum Haas Mills
    Last Post: 02-01-2007, 12:52 AM
  4. Compressor
    By Crazycorkey in forum Hobby Discussion
    Last Post: 01-30-2007, 10:02 AM
  5. Compressor wheel
    By Chubs in forum Hobby Discussion
    Last Post: 11-04-2006, 01:19 AM
