586,108 active members*
3,175 visitors online*
Results 1 to 13 of 13
    Dec 2008
    8
    CNC with touch cut plasma system
    Hi all,
    I am quite new in the CNC world and even newer in the plasma cutter community.
    Rather than a long introduction please visit my web page devoted to my hobbies : http://freedom2000.free.fr/index.html
    I would like to buy a small chineese plasma cutter 50A. It is a "touch to cut" system. Do you think that such a system is convenient for a cnc;
    could I use it in the following manner ?
    - z axis down to touch
    - arc ignition
    - z axis up
    - cnc cutting
    - arc off
    is there a risk to burn the torch if starting the arc in plain material ?
    another question : what do you think about this cheap unit :
    http://www.pellet-mill.de/shop/article_CUT-50A/INVERTER-CUT-50.html?sessid=HTSKjXzd2q4MlVABgRDjPHrs0lhNDaAOYA1 MwYlOsCIcrfSlc9gmPgbKPAlks3xR&shop_param=cid%3D16%26aid%3DCUT-50A%26
    or the same in english http://www.rsweld.com/Air-Plasma-Cut...t40-Cut50-376/
    thanks in advance
    JP
    Dec 2004
    312
    from my experience and i suggest ya get a good quality brand name plasma cutter to reduce headache and problems
    such as hypertherm (i suggest ya get hypertherm machine)
    Dec 2008
    8
    Quote Originally Posted by DanOSB View Post
    Yes thanks for the advice --> I will probably choose a better brand
    However, this answers only partially to my questions...
    The most important for me is to know if it is possible or not to use a simple plasma cutter "touch to start cutting" with a CNC or if it is mandatory to use an "auto start device" (that is the torch doesn't need to touch the metal to start cutting --> see this nice smiley !!! (flame2)).
    JP
    Dec 2004
    312
    for my cnc using hypertherm i have a microswitch so before i start peircing the part it touch the metal and then go back up to .125" then cut the material
    the perfect height of peirce will make the consumable last longer
    if you are cutting too low or too high it can shorten the life of consumable..
    Jun 2007
    268
    Jp
    Im not sure what touch to start cutting means, i looked at the web site and tried to find more information on that, but there isnt much to go on, if it means the torch is touching the plate to fire and cut i would assume it is a sheild on the nozzle allowing you to drag the torch along the metal while cutting, this would apply to hand torch cutting only, most cnc machines lower the torch and touch the metal, lift off to peirce height, peirce, then lower to the cutting height and begin cutting, with cnc your torch is vertical and the further away from the plate you are while peircing the less of the chance of spatter blowing back up into your nossle and ruining the nozzle/electrode...( consumables )
    I also tried to find a list of consumables for the cutter you mentioned, maybe its me but i couldnt locate that either on their web site, what i did find was a list of safety procedures for there plasma cutters, do's and dont's... which was interesting to read. I dont know what the price tag is on this cutter, but sometimes less expensive tools cost more in the long run by poor performance and lost time due to break downs, lack of support from the manufacturer, cost of consumables, and wasted material from bad cuts... If you are just going to use it as a hand held cutter is may be ok, if you have plans in the future for using it for cnc i would seriously consider upgrading to one of the more common brand name cutters like Hypertherm as DanOSB mentioned, i own a 1250 Hypertherm and it works flawlessly, and there are different types and sizes of nozzles for different range of application, they have a newer style 45 amp cutter availible now, from what i have heard and read it cuts beautifully and is priced around $ 1600 US, Hypertherm specialize in plasma cutters, its all they make and they take safety seriously....and after reading the safety part on rstar web site it may be something to consider also...and Hypertherm being a more popular cutter, there are more users on sites like this one that can help you if and when you decide to go cnc.....
    Regards
    EDD
    Dec 2008
    8
    Quote Originally Posted by Edwardo View Post
    Jp
    Regards
    EDD
    Thanks so much for these clear explainations and advices. It is exactly what I wanted to know.
    To be fully clear, can you confirm that the torch ignition starts as soon as the torch is in contact with the metal ?
    JP
    Jun 2007
    268
    Negative on that.... the torch lowers and touches the metal before firering, it does this to find the top of the metal, height will vary with different thicknesses of metal, then rises to a pre-set peirce height, then fires and blows a hole through the metal, then the torch lowers to the pre-set cutting hieght and continues cutting... this all happens within a very short period of time... with thicker metal you can also set a peirce delay to ensure that the hole is completely blown through the metal before the torch begins to lower to the cutting height to avoid the splash back of molten metal into the torch nozzle. Ideally with my torch and cnc, you never want the torch to touch the metal when it is peircing or cutting, it will ruin the nozzle and possible the the electrode inside... which is the least damage that can occur.... check youtube and seach Dynatorch... there are videos that show the cnc plasma torches working, you will see what i mean...
    EDD
    Dec 2008
    8
    EDD
    OK thanks again. This was the final precision that I wanted to get !
    The cheap model that I suggested is ONLY starting the arc when touching the metal. You have then to climb up a bit. But while this happens the torch is on... which can probably ruin the torch during this (short) delay ???
    JP
    Jul 2005
    2415
    Contact start plasma torches that use the workpiece for arc start are not going to work for mechanized (CNC) cutting. At the very least get a plasma cutter that has HF start so it will start an arc in the air. It's difficult enough to get a good plasma cut without throwing in a toy plasma cutter.
    TOM Caudle
    www.CandCNC.com
    Dec 2008
    8
    Quote Originally Posted by Torchhead View Post
    TOM Caudle
    www.CandCNC.com
    OK gentlemen,
    It's clear enough now, I will NOT buy this plasma cutter and look for a good one.
    Thanks again for your help.
    JP
    Aug 2009
    I say thanks too I was wondering how they worked
    Jul 2006
    215
    go for a hypertherm you can't go wrong with them.
    I have a Chinese Plasma 40A Cutter that I use for cutting sheets down for my CNC Plasma (That uses a Hypertherm )
    I think that it could be made to work, but you would have a lot of problems with false starts.
    On a CNC with a THC (Torch Height Controller) the machine waits for the Arc Signal from the plasma cutter, and they only move when the arc is good.
    I think it would be very annoying to keep having to rewind the program to do missed cuts
    Save pulling your hair out, and buy a Hypertherm or similar
    Andy
  1. Buy or build a cnc plasma system
    By FABMAN in forum Waterjet General Topics
    Last Post: 04-04-2008, 03:28 AM
  2. THC in Plasma system.
    By samakthachai in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-30-2007, 06:27 PM
  3. Plans for Plasma table and which system
    By metalcraft.hr in forum Waterjet General Topics
    Last Post: 05-27-2007, 03:01 PM
  4. which plasma system cnc
    By marcmnrsports in forum Waterjet General Topics
    Last Post: 04-09-2007, 04:29 PM
  5. What rail and bearing system to use for plasma table?
    By Apples in forum Waterjet General Topics
    Last Post: 05-22-2005, 05:57 AM
