586,103 active members*
3,549 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF-2 stops in the middle of a program!!
Results 1 to 7 of 7
    Oct 2005
    225
    When I simulate a 3-d part on the VF-2 it stops about 3/4 of the way through
    the program. When it stops it locks up the machine and I have to shut it down to reset it. Anyone have a clue to why it just stops. When I load the program I have 20% memory left. The program is about 25000 lines and it runs to line 18751 approx. but it is the same line every time. The line where it
    stops is just an x y and z move with nothing special.
    Tommy
    4826
    Do you only have the one program in memory? IOW, could you make some more room by removing some programs to see if that makes a difference?
    Other than that, I'm not sure. Does cutter comp happen to be active in the area where the hang occurs? I've had the odd instance where the machine would stop moving during a compensated path, but it is rare.
    What version is your Haas software? That might help someone diagnose the problem.
    Oct 2005
    225
    Thanks for the reply.
    The machine is original to 1990 I believe. I could try and clear all other programs and there is no cutter comp. involved. It is just cutting with a .25 ball nose endmill, standard 3-d moves. Is there any parameters that would stop it from running a set number of lines(just a guess)
    Tommy
    Dec 2008
    3109
    Quote Originally Posted by southernexplore View Post
    A lot of controls read ahead a certain number of lines, are you sure that the line it stops on is the problem, or one that has just gone into the buffer ??
    Going into single step just before the "bad" area and stepping through would fine tune the actual offending code if it exists, as the read ahead function is a bit more restricted.
    Oct 2005
    225
    I will try to step into it and see!
    Tommy
    Jun 2008
    62
    Is there a remote possibility you have a feed rate with no decimal point? Considering this large program was posted and has been running, I doubt it left out a decimal, but it's had me stumped before.
    Oct 2005
    225
    To answer the question on feed rate without a decimal, nothing was missing, it was running a 3-D program that had the same feed rate for approx. 20,000 lines.
    I give up on that drawing and g-code post.
    I made some changes to the drawing and was able to cut it with no problems.
    Thanks for the help everyone!
    Tommy
  1. starting in the middle of a program
    By panaceabea in forum Milltronics
    Last Post: 05-19-2009, 02:54 PM
  2. locked up in middle of program
    By nmn in forum Haas Mills
    Last Post: 03-31-2009, 03:33 AM
  3. starting from the middle of a program
    By panaceabea in forum Haas Mills
    Last Post: 03-28-2009, 12:31 AM
  4. Starting in the middle of a program.Old control.
    By lostkoss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-07-2008, 03:11 PM
  5. Hass VF6 how do you stop in middle of program
    By SpringKing in forum Haas Mills
    Last Post: 05-14-2007, 04:07 PM
