586,104 active members*
3,353 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Spindle encoder shot.. I am going to repair it
Results 1 to 19 of 19
    Oct 2008
    45
    Ok, have an older spindle encoder, the type that is on top of the motor under a little cover, and is basically a toothed gear with a pickup that reads the teeth as they go by..
    Now, it originally worked, but not well. At high speeds in the CW direction it would lose counts.. In reverse, it worked great..
    Well, I went up there to reset the gap to try to get a bit more sensitivity out of the pickup, and I started it up and it turns about a quarter turn, then shuts off. No tacho signal is present at all now according to the control panel in either direction.
    I noticed that there is an adjuster screw that seems to move the pickup sensor back and forth in very small increments. I still get nothing.
    I know that the pickup has to have an excitation voltage (similiar to the pickup on a guitar)
    I guess I will start there and see. I would suspect that there is a bad connection somewhere between the pickup and the main processor.
    My most important question is, anyone know where the connection is made within the panel for the tacho pickup? I am thinking about just rewiring it with high quality shielded multiconductor wire and seeing if that helps. From the pedestrian schemos that are provided with the owners manual, I can't really tell.
    Thanks in advance for any help anyone can throw my way!
    Jan 2007
    355
    Check for physical damage to the sensor. If the sensor came in contact with the gear teeth, it will have to be replaced.
    Your setup sounds similar to the one used on our Okuma lathe live tool spindle. The gap between sensor and gear was very small, probably about .020.
    Had to replace a few sensors due to careless installation.
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Oct 2008
    45
    ok, new pickup sensor it is..
    Wow, the sensor is that sensitive that touching it off on the gear will destroy it??!?!
    Incredible.. Well, when I first took it off to look at it, it had a rub mark on it before I even tried to adjust it so maybe thats what went on with it and why it was acting up.
    I really dislike pickups like that.
    Now I see why later they moved to the gear driven optical or hall effect tachos.. These types of sensors go out on cars quite a bit more than I like also. The biggest problem is when they go out, they do it in a way that its hard to diagnose exactly what the problem may be.
    I think there is a company that makes a conversion for this that I may look into later..
    Next step: where do I get the pickup sensor? And how much are they usually?
    Aug 2005
    1622
    Sounds like a typical prox switch application. Although prox switches are far from typical in specifications and characteristics
    Depending on the configuration of the body, there may be numbers on it to reference. If not, you'd need to know the voltage, frequency limits and field sensitivity to save a few bucks on a cross referenced part.
    Calling any online Fanuc supporting parts supplier with a Manufacturer, model and serial number could save some time. If you have the part number out of the manual, do a search and see what pops up.
    DC
    24221
    Many manufacturers use a similar PWG for spindle rpm detection, both Fanuc and Mitsubishi tend to use Matsu****a and Tamagawa made components for these kind of detectors and tachs etc, these are often custom made for each of their OEM's.
    Al.
    I forgot about the automatic editing, the Manuf in question sound like Matsusheeta!
    Albert E.
    Oct 2008
    45
    If I could find the complete schematic of the in and out of this thing, or if I could see what the signals look like I could make something that would replace this..
    Anybody got schemos of this bugger?
    I know everyone will say "oh just buy another one will ya" but thats not how I work nor do I have that kind of cash.. $400 for a new one is just not possible..
    May 2009
    181
    ok you are missing some steps here..
    1) what control is on this machine
    2) how do you know that its missing the "tacho" signal? You have a scope?
    3) what alarm is this thing giving you?
    4) are you sure that this sensor is the problem and not a separate position coder?
    5) this ring and magnetic sensor arent old technology.. new ones use them too..
    the motors that have a magnetic drum and a sensor are high resolution ones..
    6) if you believe that this is the problem you need to adjust the sensor to the gear it needs to be 6 thousands away from the gear.. use a feeler gauge..
    7) are there any marks or scratches in the senor?
    8) have you checked the feedback cable yet?
    Oct 2008
    45
    Its a 3m
    Yep. Got a really nice Fluke that does it all.. Saw some irregularity in the signal when CW.. I readjusted it and it worked ok for a bit, then it simply stopped working.. First sign was that it would *miss* pulses in CW and act up. I would have to warm it up for about 3 hours before it would smooth out and allow me to cut anything..
    8... Pretty generic..
    Its most likely the tach sensor.. Thats what I am going after now.. The spindle worked *great* in CCW, but not in CW. I don't think the position encoder would cause that..
    Well, for some reason Kitamura swapped them over for the little gear type later on..
    I tried everything from 10 thou to around 2 thou and couldn't get it to fire back up..
    That was the FIRST thing I noticed.. The tacho gear had rubbed it.. I saw it before I even adjusted it by shining an led flashlight in there.. It had been hit before I even got at it..
    Yep, it rings out solid.. I even contemplated rewiring it from the spindle controller to the pickup just because I figure its prlly some old wiring and may need some help
    One thing I *did* notice is the shielding on the cable isn't grounded on either end (!?). Sorta strange, but, I do know that sometimes you leave it floating depending on the app. right now I am not getting anything out of it from what I can tell..
    I need to play around with it some more.. Another thing that gets me is, the sensor may be out, however, there really isn't *much* to break? I wonder if its possible just to rebias the circuit to deal with what looks like a decrease in output from the sensor?
    At any rate, I got a bit more to look at before I figure out how to get this thing running again..
    May 2009
    181
    Quote Originally Posted by SSMrob View Post
    1)
    ok good so this is a dc spindle or ac?
    as far as the sensor goes.. i have replaced a ton of these.... if there is scratches on it just replace it... call fanuc and give them the part number off the motor and they will be able to give you a price on the sensor..
    if the senor is having a problem you will usually see someting like 5volts or more on Pa and Pb check pins on the spindle board..
    but alarm 8 is overvoltage usually on the 24 volt check pins.. check that..
    i would also check incoming power to drive...
    the other thing to try is to swap the board if you have a spare or another machine.. on the spindle drive you might have a board problem since its going in 1 direction..
    i would honestly call fanuc their advice over the phone is great i bust their balls all the time with questions they are good for it.. lol
    Oct 2008
    45
    Spindle is DC..
    the alarm 8 isn't at the spindle controller, it is at the panel...
    on the PIL it lights up the 2 in the 8421 output..
    Well, so far, we pretty much know the sensor is toast with all the scratches it had on it. It was rubbed up pretty badly..
    If that doesn't do it, then, its on to start trying to route it back to something else..
    May 2009
    181
    Spindle is DC..
    ok then perfect.. alarm 2 is speed deviation or signal loss..
    check PA and PB with a meter on ac and if you see something like 5 volts the sensor is definitely bad..
    Apr 2006
    822
    mean while... back at the ranch... well over $400 of lost production has flown out the window!
    Are you really sure you can NOT afford the measly amount i would cost to do this job as stated earlier?
    Seems like you must be charging only a few dollars per day for your time if it is okay to spend this amount of time fixing this problem.
    Nov 2006
    175
    Have you tried to adjust the pa/pb signals on the spindle board?
    Sorry, no schematics with me, I'll be a bit descriptive. You will need an oscilloscope and a friend to rotate the motor slowly but with constant speed as possible.
    There are two check pins around the feedbach connector, after a 1458 or similar op.amplifier, where you should see on the oscilloscope squared signals of pa and pb. There are also two trimpots there, rotating motor slowly by hand, adjust that two signals have 50% duty each, and exactly on 90 degrees. Repeat for both directions.
    If only squared signals enters the board, theese pots are on the encoder board.
    May 2009
    181
    Quote Originally Posted by f-bu View Post
    Pa and Pb are not square wave signals... PA PB are sinusoidal signals and you dont adjust any pots..
    you need to move the motor by had and then check with a scope to get about .6 volt peak to peak..
    Nov 2006
    175
    From the magnetic sensor pick-up you get sinusoidal signals, right. BUT, in the board, they are compared and made square. I explained adjustment of the sin-sq converter on spindle control board.
    Also, there were small size motors, say model 3, that had no DC tacho generator, but magnetic encoder, nearly same type as the one used in first AC spindles. AFAIR adjustment was made on the "tacho" board
    May 2009
    181
    well you need to be more descriptive then because what you are telling him to check is pa and pb check pins which are ALWAYS analog sine waves..
    pap and pbp are square wave and need to be set at 50% duty..
    Oct 2008
    45
    Quote Originally Posted by broby View Post
    yep, doesn't really matter since where we are at right now is pretty much hosed as far as business is concerned.
    I had to wait for the $$$ to show up to fix the thing.. Guy just walked in with a 1k job, so thats a start and will pay for this..
    Don't know about you, but we are absolutely hand to mouth right now...
    Apr 2006
    822
    Such a fair comment... So true about having the funds up front to pay for such a repair... real catch 22 situation, need the money to pay for the repairs, but need the machine to generate the money to pay for the repairs but do not have the money to repair said machine... hmm what to do?
    Good luck I hope you can fix it some how.
    Cheers
    Brian.
    Oct 2008
    45
    Thanks man!
    And, yes, I bought the little bugger, fired up first go so we are ready to finally make some $$$.. We get to pay bills another month..
    Crazy thing is, I dunno how anyone else is doing it ie making money.. I take the craziest jobs and do the strangest things for money anymore..Esp. if you are a new business..
    Also, AMAZING amount of in-depth information in here!! Absolutely incredible!! Thanks to all!!
  1. Spindle Repair-Brother TC-221
    By Ben Colby in forum Uncategorised MetalWorking Machines
    Last Post: 02-04-2023, 12:18 AM
  2. BP 760/22 Spindle Repair
    By KTD1 in forum Bridgeport / Hardinge Mills
    Last Post: 09-05-2014, 03:51 PM
  3. INTEGREX 300SY SPINDLE REPAIR
    By CHAD LAWSON in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-14-2009, 04:08 AM
  4. CNC spindle repair
    By Mikecarter in forum DNC Problems and Solutions
    Last Post: 02-16-2009, 02:55 AM
  5. Mill spindle repair?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 04-02-2005, 07:01 PM
