586,103 active members*
3,456 visitors online*
    Aug 2009
    Question Sherline Lathe & Bob Cad-Cam v23
    I'm using Bob Cam-Cad v23. for G-Code generation of my drawn part inported into my Sherline Lathe using Mach 3..When I start the G-CODE for the drawn part I get and error code that says that it cant turn radius in the xy axis..Any help would be greatly appreciated..Thanks
    Jan 2006
    357
    Quote Originally Posted by tip View Post
    It sounds like your not in lathe mode, up at the top select modules, then select turning mode, There is only X&Z in standard lathes
  1. Sherline Cnc 4400 Lathe
    By STIELJTES in forum Mini Lathe
    Last Post: 08-09-2009, 12:59 PM
  2. 7x CNC Lathe or sherline?
    By Jason23 in forum Uncategorised MetalWorking Machines
    Last Post: 09-10-2008, 06:08 AM
  3. What Sherline Lathe Accessories To Buy And When?
    By Too_Many_Tools in forum Mini Lathe
    Last Post: 10-11-2007, 05:46 AM
  4. Sherline lathe question
    By bnalls in forum Mini Lathe
    Last Post: 08-15-2007, 02:44 AM
  5. Sherline 4000 Lathe
    By sleepy23 in forum Mini Lathe
    Last Post: 11-09-2005, 10:44 PM
