I have a D&M milling machine that I converted to run with Mach 3 software and have a strange problem with the Z axis. Once and a while the Z axis motor acts up and only runs in one direction no matter what I tell it to do. If I play around with the software settings I can get it to go the other direction for a moment and then it resumes it's problems and only runs in one direction. I had this problem in the past and it went away by it's self after messing around with the machine for a while. The problem came back this week after I unmounted the stepper motor to adjust the ball screw and put it back on, none of the wiring was unplugged when I did this. I also tried a different stepper drive in the past and the problem didn't go away so I don't think the drives are at fault.
Could there be a short in the motor wiring or can the direction signal get messed up by interference inside the machine? I have looked at every thing and it seems OK, and hope someone can tell me where I should start trouble shooting for the problem.
Thanks for the help!
Dale P.
