586,645 active members*
2,744 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > linear rods versus linear rails
    Jul 2009
    11
    there seems to be a bit of confusion on this hell I am to, I hear one place say rods are best for this or that then I hear the same thing about rails?? I am wanting to figure out which is best on what standing point's accuracy, load, which one keeps it's accuracy longer, life span, etc?? there are three type's used most and easiest to find is as fallows
    standard rod's using round linear bearing's
    rod's connected to a support rail system split round bearing
    rail system using bearing cartridges (flat) such as a ssr15 thk rail
    I am sure a lot of people have experience with one or two of these systems
    and some I am sure with all of them at a time or another simple asking you to share your experience with them
    and may be help out some new builders make a better informed decision when selecting rails
    May 2007
    17
    Post rail types
    Round type (thompson etc) dont have any curved grooves machined into them for the ball bearings to ride in like LM guides (flat type linear rail), hence they need more bearing columns to distribute side load as the bearings only make contact on their outer edge, vs a more supported LM guide which has half of the bearing in contact with the rail.
    LM guide (flat rail) type generally have a higher load capacity and last longer, but depends on size, you would need to check manufacturer's specs to compare LM and round, then assess your budget and which would be easier to mount.
    As for round rail, supported and unsupported, as a general rule, supported should be used for higher load / smaller diameter rail / long span applications etc, and unsupported for short length / large diameter rail or light load use etc.
    Check specs, or do a flex test with scale etc.
    Hope this helps you at least a little.
    Jul 2009
    6
    thompson or thk???
    I've worked on a machine for a friend.... early '80 cincinatti... round rods, split bearings - the bearings were shot and totally worn out. they would have lasted longer if there was a way to lube them. Rod diameter 2 1/2 inches, weight of just the machine table on them 7000 Lb. Machine was used for mold making = lots of back and forth movement!!!!
    S
    PS: I'm parting out the machine! (and it has almost new rods and bearings in the 'Y' axis!)
    Running Okuma: Cadet Mate x2, MC4VAE, Crown-BB, MC40VA-HS
    Jul 2009
    11
    thank you have a new question I have seen people with listings for rail's lm sr20 ssr25 and such having the ends machined to line them together to get extra length I would thingk this might effect accuracy at least a little bit what do you people think?
    Dec 2008
    445
    Quote Originally Posted by haylspa View Post
    Get hold of the hiwin documentation, it has the answers to most of your questions, and relates the tolerances given to their rails. Other manufacturers will provide the spec data, but aren't as clear as some of the hiwin illustrations. They show how one can line up two sections of rail, but you can get pretty long sections already. As long as the carriages and rails are of the interchangeable type, there should not be any issue.
    They will also give load specs per various rail sizes, which is good info to have.
    In order to set up any precision set of rails, you need a good dial test indicator, generally one that reads in .0001".
  1. Linear rails
    By lgalla in forum Linear and Rotary Motion
    Last Post: 08-22-2006, 09:48 AM
  2. Linear rods and linear brushings
    By Com in forum Linear and Rotary Motion
    Last Post: 06-28-2005, 11:48 AM
  3. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
  4. linear slide rods for sale in the Netherlands
    By Tjippy in forum DIY CNC Router Table Machines
    Last Post: 12-06-2004, 08:46 PM
  5. How do Thomson linear rods work?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 09-01-2004, 01:52 PM
