586,070 active members*
3,592 visitors online*
    Dec 2007
    10
    Question probing in a okuma 56va
    Hi
    Does any one know if it is possible to write your own routines e.g. probe a bore in three places at given angles.
    Apr 2006
    822
    Quote Originally Posted by raymond.baker8@ View Post
    Hi
    ANYTHING is possible... the hard part is calculating the actual contact point at the angle to the major axis lines.
    You can use the G31 skip function to detect probe activation (Renishaw probe I assume?) but then you need to take into account the shape of the probe and offset for the ball diameter etc...
    If you are only after a "Roughy" position, it should not be too hard, depends on how many free areas on the nearby walls you have left to bang your head in frustration on
    We have written a few different types of "non-std" probing routines over the years and I can assure you, if there is an Okuma routine that you can use... use it!
    Cheers
    Brian.
    Dec 2007
    10
    Hi Brian.
    Thank you for the information I will try this out tomorrow.
    Cheers
    Ray
    Aug 2006
    62
    Why not buy the Inspection-plus macros from Renishaw $1076
  1. probing
    By Freddy Bastard in forum Tormach Personal CNC Mill
    Last Post: 08-22-2009, 04:02 AM
  2. Probing? anyone?
    Last Post: 07-05-2009, 03:07 AM
  3. Replies: 1
    Last Post: 08-28-2008, 02:09 PM
  4. Difference between a Okuma & Okuma Howa
    By 69owb in forum Okuma
    Last Post: 06-04-2008, 05:51 PM
  5. Probing?
    By chunkymonkey in forum Uncategorised MetalWorking Machines
    Last Post: 04-02-2008, 05:39 AM
