Thanks MattTheNoob,
ust a bit frustraighted that I don´t hear from the vendors.. But I will be passions..
Mike,
Thanks as well.. All the help is appreciated..
I think the wirering is good enough. It is the middle brown wire that is 5V+ from the BOB. This goes into (TERM. 12) on the Gecko. I have messured 5V+ on it, so it should be ok. There is a jumper on the BOB where I can set it to Ground or 5V+ on the COM output. So that is correct.
Jumpers are on default. Haven´t tutched them..
External power supply? A danish guy who has bought the same KIT has not mentioned this when he saw the picture. But I am using 5V+ witch comes from the power supply into the BOB and then out to the Gecko. Is that what you call external? I just cannot see that I need to add a 470 ohm resistor when both Keling and Marco at Gecko hasn´t mentioned this after viewing the picture.... But let me know your thoughts on this..
You say it is difficult to set up the Geckos. How should approuch it. Leaving Gain and DAMP to 9 0´clock position and have the LIMIT all the way CCW. I have 5V+ between #5 and #7 all the time, and when I turn the LIMIT 1mm CW the FAULT lights pops up and it starts to (chock...chock) every secund. The higher I turn the LIMIT the more power it gets on each (chock...chock)
I have switched the white A and the brown B on the encoders to the driver and it does not help. Switching the power to the motor should give the same results as doing this.
Should I do somthing with the jumpers on the AMT102-V Optical Encoder?
Let me know your opinion.. Thanks again Mike...
