586,089 active members*
3,776 visitors online*
Results 1 to 13 of 13
    Aug 2009
    14
    i have a problem
    i have this problem. Can you help me?
    Jun 2006
    43
    you need to home all of the axis X,Y & Z.
    Aug 2009
    14
    thanks. Now, i have this problems. i don't know how to configure the emc2.
    I just set the stepping motors, but the other I put in the unused pins
    Aug 2009
    14
    Why set limits?
    Nov 2005
    496
    That message means you would exceed the software limits.
    Limits are designed to stop the axis movement before it gets to end of physical travel.
    There are hardware limits and software limits.
    Hardware limits are what you connect to switches.
    software limits are based from home location and table travel.
    (I am assuming you used stepconf to make the configuration)
    read this:
    http://www.linuxcnc.org/docs/2.3/htm...is-Travel-Home
    Soft limits, while annoying to set up in the beginning is designed to stop crashes and tells you if the program you are running has asked EMC to move an axis beyond the physical travel before it actually moves the axis.
    Aug 2009
    14
    Thank you very much for your help.
    then I would be using soft limits, and my problem is not set.
    Can it be that the parameters I have to configure are these?
    Nov 2005
    496
    yes set the home switch location to zero as you don't have home switches.
    Then with home position set at zero and table travel set to -4 and 4
    you would need to move the axis to the middle of travel and home, as 0 is half way between -4 and 4.
    I'm pretty sure that is how this works. I use home switches.
    bottom line is you have to home in the right position for soft limits to work.
    Aug 2009
    14
    thanks.that was the problem.
    I never knew either micorpasos and set the leadscrew pitch. Can someone help me?
    is obtained as the leadscrew pitch and microsteps?.
    to calculate the leadscrew pitch 1/tpi use. this is right?
    Jun 2003
    3312
    Quote Originally Posted by Claudiosd View Post
    Are you using stepconf to setup your needs? It asks pitch and microstepping seperately.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Aug 2009
    14
    Quote Originally Posted by pminmo View Post
    yes, i'm using stepconf.
    relationship between motor and leadscrew is (1:1).
    I think the pitch is calculated:
    p = 1/tpi
    and this value must be re-divide it by one to calculate rev / inch:
    rev / inch = 1 / p
    This is true, or wrong?
    microsteps not know anything about me and I needed to explain a little about this.
    Jun 2003
    3312
    p = 1/tpi
    rev / inch = 1 / p
    p=1/tpi.....IF it is a single start screw.
    Aug 2009
    14
    I'm using single start screw.I use two formulas to explain the above?.
    or just p = 1/tpi?
    Apr 2007
    56
    Yes, the pitch = 1/Threads Per Iinch, but the pitch isn't the same as steps per inch.
    You will need to know how many steps the motor needs to make one revolution. You've mentioned micro-stepping. You will need to know how many micro steps per revolution. I have a small mill that I can use as an example.
    I the lead screw I have has 20 TPI. The motor takes 200 steps per revolution. The Gecko controller I use has 10 micro-steps per step.
    So, the number of steps per inch = 10 (micro-steps) X 200 (steps per revolution) X 20 (threads) = 40,000. If you use metric, the formula is the same except for threads per inch, it would be threads per unit of measure.
    I hope this helps
    Regards,
    Bill K.
  1. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
