dear all
how to download pmc ladder from fanuc 0i/18i/31i.not parameter.
thank all
dear all
thank all
press system
pmc
I/0
output to memory card
select data type as ladder
press execute
hello fanucman
thank you
i cannot find i/o softkey in fanuc32i.
best regards
hong
thanks.
thıs method for download
I want to leorn,
ladder = plc ?? SAme ??
what is the ladder upload method ?
how to install the ladder.?
I am a rookie in service. I learned a lot from this forum
thanks
KİNG NOTHİNG
try SYSTEM > > PMCMNT - I/O
wıll we select Read ?
KİNG NOTHİNG
SYSTEM > > PMCMNT - I/O - MEMORY_CARD-WRITE-SEQUENCE_PROGRAM
Enter some file name, INPUT, EXEC
status has also changed ladder cnc.
and we can install these instructions ladder.
;Hello neighbor country.
ı m from turkey / istanbul.
KİNG NOTHİNG
Komshu, this sequence was for writing PMC program (called also ladder) to memory card. What you want to do? If you want to install a new ladder from memory card, you must select READ instead of WRITE in the above mentioned. Be VERY CAREFUL, the machine can be dangereous with wrong ladder!
ало. Брат ми
I know
Manufacturers will send the ladder to be installed
KİNG NOTHİNG
Why do you need new ladder ?
your machine LAthe or vertical center ?
Who is the Manufacturers
thanks Hemşehrim
DEAR ,,
We are pushing feed hold button (any where - at any time in automatic working )
chuck and coolant are stopping. it s normal.
after,
We are repeat pushing cycle start when chuck starting but coolant isn't working ( auto coolant lamp running )
We'll have to manually press the manuel coolant button again. ( or tools are corrupted )
is pressed to start the water flowing again.
KİNG NOTHİNG
