586,116 active members*
3,386 visitors online*
Page 1 of 23 12311
Results 1 to 20 of 443
    May 2008
    4068
    CNC parts Toronto
    Hi, I have a full line of CNC pats in the Toronto area , if your looking for c5 ballscrews and linear rails .motors .driver, spindles almost all parts you would need
    Thanks for your time
    Jun 2007
    3891
    website? specs? prices? details? !!!!
    May 2008
    4068
    No site as of yet till we have all products in , but once we have all here and have outlet open for pick up we will have the site with all info up and running, If your are looking for products i could till you when they will arrive and the price, we will have almost every part and more Thanks
    Have all linear rails and bearing in right now from 16mm to 25mm and c5 ballscrews by the 21 aug
    Sep 2005
    1660
    What length of ballscrews do you have access to? Diameter?
    I'm in the market for a ~12ft long unit in a 1.5" od... fairly tight on the lead
    Is that something you might have access to?
    Thnx
    J
    JerryFlyGuy
    The more I know... the more I realize I don't
    May 2008
    4068
    largest i have right now is 25mm 2800mm Thanks
    Feb 2006
    18
    Is your website up and running? Link...? Tnxs
    May 2008
    4068
    No, but should be up by end of sept
    Jun 2007
    3891
    its past aug 21.
    im curious what you have for c5 ball screws.
    my mill project needs 16mm screws, with 175/320/275mm travels with machined ends for thk "BK" style bearing blocks.
    what kind of price would that be?
    Oct 2007
    1025
    contact
    could you conatct me at [email protected]
    May 2008
    4068
    1605-4 PER 100MM $6.50
    2005-4 PER 100MM $7.50
    2505-4 PER 100MM $9.75
    high precision rolled ± 25µm/300mm
    MACHINED BOTH ENDS FOR BK.FK AND FK.FF IS $20 PLUS
    Have machined 200mm.254mm,300mm,600mm,900mm and 1200mm in TRAVEL (PLUS 81MM FOR MACHINING) on the 1605
    Have machined 200mm.254mm,300mm,600mm,900mm and 1200mm in TRAVEL (PLUS 61MM FOR MACHINING) on the 2005
    1605 BALLNUT $59
    2005 BALLNUT $65
    2505 BALLNUT $70
    i will list more later today
    Oct 2007
    1025
    looking for more
    looking for gecko drives ,high torque stepper motors,lathe indexer parts someone to build and add the fourth axis
    May 2008
    4068
    You can email me at [email protected]
    May 2008
    4068
    Don't have grecko but have 4.2a and 8.2a driver with breakout board
    May 2008
    4068
    16mm rails is $1.75 per 100mm
    sma 16mm block $6.90
    sma-s 16mm block $8.62
    sma-L 16mm block $14.50
    20mm rail $2,25 per 100mm
    sma 20mm block $8
    sma-s 20mm block $10.25
    sma-L block $16
    25mm rail $3.00 per 100mm
    sma-25mm block $14
    sma-L block $29
    May 2008
    4068
    TBR 16MM $4.30 per 100mm
    BLOCKS $10
    SBR 16MM $4 PER 100MM
    BLOCKS $ 8
    TBR 20MM PER 100MM $ 5
    BLOCKS $13
    SBR 20MM PER 100MM $4.65
    BLOCKS $9
    TBR 25mm PER 100MM $6.30
    BLOCKS $19
    all prices are in Canadian dollar
    Jun 2007
    3891
    Quote Originally Posted by gio666 View Post
    1605 BALLNUT $59
    2005 BALLNUT $65
    2505 BALLNUT $70
    seal both ends and not plastic wipers that mite fall off at high speed
    got any pictures of the screws?
    so these are c5 rolled screws with no backlash? havent seen many rolled screws at that precision. prices seem good though.
    now i just need this machine cast
    you mentioned some other stuff in your first post. spindles, motors. what type do you have of these?
    for linear rails, i assume its just round rails correct?
    May 2008
    4068
    I will post pictures of ballscrews tomorrow , they are high precision rolled and not from china,also have 2 year warranty 0.018 guarantee ,lots of companys produce 0.018 but people dont want to spend the extra money and just get 0.023 or higher , i will give prices on spindles,inverters and motors and other but i only but the prices on products we have here as of now . More products coming every week, plus have a lot of parts made in Canada ,as in motor mounts ,cnc frames ,coupling ,z axis ,end support bearing housings , y axis,and x axiz frame's and made in north american aluminum . 270oz motor will be $29 and 425oz $ 35 CDN but i will post the prices of products that will be here in sept, the prices there are for round rails and TBR and SBR supported rails, We are trying to make as much of the parts in North America as we can , with out prices being unreal.because if a part is $7 made in can or usa people would buy it from other country if it was $5
    Jun 2007
    3891
    cool. you need to get a website going man
    heres an example lits of parts i need for my open source mill - small/medium/large
    ball screws, C5 or better, 5mm lead, 16mm/20mm/25mm diametre.
    BK bearing blocks to match screws.
    linear profile rails, narrow block, ball or roller, 20mm/25mm/30mm.
    brushless spindle motor with inverters, 6000-12000rpm, 1-3KW.
    high speed spindle motors with inverters. ER chuck or iso ATC. 24000rpm+.
    brushless ac servo motors with drives, nema23/1NM/3000rpm, nema34/2nm/3000rpm with step direction input drives.
    trying to get inexpensive but still high quality components to keep these machines at good prices.
    May 2008
    4068
    We have c3 ground ballscrews but don't have final price on them till they arrive here ,about around 20% more in price, We have HSD spindles and water cooled 1,5kw $300 and 2,2kw for $400 and 3kw $500 plus the exchange rate at the time .inverter are1.5,2,2kw $160 and 3.7$260 plus exchange rate usd, but there a month away becuse of shipping
    Jun 2007
    3891
    We have c3 ground ballscrews but done have final price on them till they arrive here ,about around 20% more in price, we have HSD spindles and water cooled 1,5kw $300 and 2,2kw for $400 and 3kw $500 plus the exchange rate at the time .inverter are1.5,2,2kw $160 and 3.7$260 plus exchange rate usd, but there a month away becuse of shipping
    cool. are those the same chinese spindles as on ebay/keling with an er20 chuck?
    the ground screws seem like a good option too if the price is only 20% more.
Page 1 of 23 12311
  1. Anyone in Toronto know much about laser
    By gio666 in forum Canadian Club House
    Last Post: 12-08-2008, 06:21 PM
  2. Need help with CNC retrofit near Toronto
    By L98FIERO in forum Machines running Mach Software
    Last Post: 05-22-2007, 06:06 PM
  3. Toronto machinist?
    By Eric Schlieper in forum Education - Teachers and Students Hangout
    Last Post: 03-09-2007, 03:28 AM
  4. Toronto or GTA area
    By sfr in forum Mentors & Apprentice Locator
    Last Post: 10-17-2006, 07:37 PM
  5. RFQ Milling-Toronto
    By Steve@Reliance in forum Employment Opportunity
    Last Post: 07-27-2006, 11:04 PM
