586,384 active members*
3,730 visitors online*
Results 1 to 7 of 7
    Aug 2009
    Does not complete G01 on a Sinumerik 810T
    Hello
    The company where I work has a Economos IP3200 "Sealjet" Lathe with a Sinumerik 810T controller, this machine is now refusing to complete any programme and stops on any G01 command in either X or Z plane, on the PLC screen can see the set values and the actual values of zero. Replaced the G01 command with G00 (took the material out) and it ran through until the next G01 command, tried changing the set values of G01 and still stopped at the G01 command. The problem definatly seams to be with the carrying out of G01.
    Anybody got any suggestions?
    Many Thanks
    Mike
    4826
    Missing feedrate command, perhaps? The dryrun switch?
    Aug 2009
    Feedrate is there for G01, tried changing it, no affect. Not in dryrun either.
    Feb 2008
    586
    You in inches per minute, or inches per revolution?
    Aug 2009
    Thank you. Going to look at that made me think about it again, tried to run it again and noticed that the plc was reporting S=0 when I could see the chuck spinning (can't believe that I hadn't noticed that before). Found the belt to the sensor wasn't fitted correctly, refitted it and it works again.
    Nov 2006
    925
    Siemens Automation and Drives in Manchester has free technical support.They have improved it recently in that the receptionist takes details of your problem and finds someone who knows something to call you back.Unfortunately this might be the next day but is better than the old system of putting you through to the help desk and getting someone who knew less than you about the problem.
    Mark.
    Jul 2016
    108
    Re: Does not complete G01 on a Sinumerik 810T
  1. Reviving Emcoturn 320 with Sinumerik 810T
    By smalla in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 07-16-2016, 06:29 AM
  2. Sinumerik 810T Problem
    By drundrun2008 in forum Controller & Computer Solutions
    Last Post: 04-01-2013, 12:26 PM
  3. Postprocessor for sinumerik 810t for mastercam X4
    By plcorreia in forum Mastercam
    Last Post: 10-09-2011, 09:50 AM
  4. Dnc Sinumerik 810T
    By booster05 in forum DNC Problems and Solutions
    Last Post: 11-07-2009, 07:32 PM
  5. sinumerik 810t help
    By tim b in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-22-2009, 08:23 PM
