586,103 active members*
3,630 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Apr 2008
    59
    Very thin bearings ?
    Hi All,
    I'm wondering if I could pick your collective brain power for a few moments...
    I am looking for a single or pair of very thin bearings to fit a 30mm (+/- 2mm) outer bore and a 26mm (+/- 2mm) inner bore.
    The bearing will be subjected to virtually zero load. It is used as a levelling device for a miniature camera mounted in the inner bore. It will never be rotated any faster than can be achieved by hand. The camera is in a weighted 25mm long, 26mm diam cylindrical housing. One half is heavier than the other to provide a self righting capability. A bearing at each end or a 20mm long single bearing would do. I imagine that some sort of instrument bearing(s) may be suitable.
    I've looked at ultrathin bearings but most are either the wrong size (start way too big) or are way too thick. 'Standard' ultrathin bearings seem to be about 8mm thick but are clearly designed to bear significant loads which isn't an issue for me.
    Currently I'm using the inner race of a roller bearing (26 X 30 X 20) which has a 2mm thickness but has a disadvantage of having no thrust capacity. It works great until the camera is tipped off the horizontal and it runs into the back (or front) of the housing and stops. I could solve that with the inner races from two thrust bearings but 1) this is starting to get messy and 2) overall device length is at a premium and even the width of two races may tip me over my maximum.
    My ideal solution is a 26 X 30 X 20 ultra low friction sealed bearing with a smidgeon of axial load bearing capacity.
    I have bought a 26 X 30 X 20 piece of that dry liner material (Iglidur) from IGUS. Haven't tried it yet. Not very hopefull....
    Cheers!
    Aug 2008
    573
    Could you use small loose balls, retained in a groove at the end of the inner and outer pieces by a plate on each end (for instance)?
    The bearing has almost no load, so you would not need a hard surface, just a good surface finish.
    Bill
    Dec 2008
    3109
    Try looking up "NEEDLE ROLLER BEARING" 25 x 32 x 20
    The outer race to suit your bore, rollers would run directly onto your shaft, your shaft would need extra fine finishing or grinding to a toleranced size
    and
    one that I cannot find is like a plastic sleeve or cage with ball bearings, no inner or outer shells, the bearings run directly on your parts
    something like this
    Jul 2007
    1602
    Why not a simple bushing made of Delrin or UHMW?
    Apr 2008
    59
    Hi Guys,
    Thanks for 3 really good suggestions. I'll probably try them all out.
    I'll let you know how it goes.
    Thanks!
    Apr 2008
    59
    Hi All,
    I made a (very) short video to illustrate the problem:
    http://www.tesla-turbines.com/movies/self-levelling.mpg
    I have been talking to some bearing manufacturers on how to get a bearing (or bearings) that will do the job. The race I currently have is nearly but not quite there. As the camera rotates almost back to level the unscrewing force reduces below the force required to overcome the needle roller friction. A better (read "way more expensive") bearing is required. In order to get the right one(s) I need to know the unscrewing force.
    This is some sort of torque calculation but as I had three goes at first year math I am not going to attempt this. I imagine its some sort of integration as the carrier is in the shape of a bucket. Dimensions are:
    External radius = 15.5mm
    Internal radius = 11.2mm
    height = 20.6mm
    bucket floor thickness = 3.3mm
    Total volume = 9.31 cc
    volume of each half = 4.65cc
    top half (Al 2.7g/cc) = 12.57g
    bottom half (W 19.3g/cc) = 89.83g
    Effective mass = 77.26g
    Unscrewing torque = ???
    If you can work this out all well & good, if not, pointers to how to work it out will be gratefully received.
    Cheers!
    Aug 2008
    573
    However calculated, the torque is going to approach zero at near vertical, so you're going to need a very low friction bearing for that mechanism to work reliably.
    Friction free bearings can be produced by floating the device (e.g. a ship's compass) or by using complex magnetic suspension.
    If you just want to keep the friction as small as possible then you need to reduce the diameter of the rolling surface (i.e. to reduce the contact area). Could you re-design your camera housing, so that it is suspended from the rear on a couple of small diameter bearings?
    [edit] BTW if you have to use a peripheral bearing, balls will have lower friction than needle rollers.
    Bill
    Aug 2008
    573
    another thought...
    Looking at the video, it appears you are going to use a lens cap of some description and, if the bottom half of the camera housing is to be filled with a levelling weight, the camera will look out above the centre line.
    How about a small bearing in the middle of the lens cap and a matching bearing at the rear?
    BTW are there any wires from the camera? Or are you powering with batteries , slip rings or rotary transformers?
    Bill
    Apr 2008
    59
    Hi Bill,
    I am going to attach my drawing and an XLS I did of my attempt at calculating the unscrewing torque.
    I think I've got something badly wrong as I have a torque of over 400 oz/in which cannot possibly be correct?
    BTW I am leaning towards a bearing at the front and back as suggested.
    I've been looking at Kaydon KAA10LX0's. Only available in imperial. Bore 1", Outside diam 1.375", starting torque 0.25 oz/in.
    The rotating camera holder element is a bucket shape. The camera itself is circular at 16mm for the first 15mm or so and then it has a square section for the final depth of 21mm. Wiring passes through the back of the alloy section of the bucket to a pogo pin arrangement which runs on concentric brass rings to feed power & signal in.
    Cheers!
    Attached Files Attached Files
    Aug 2008
    573
    For your purposes, this sort of info is almost meaningless. The starting torque will have been measured on proper bearing surfaces with bearing finishes, something your application will not have (nor does it need).
    If you can keep the bearing diameter down, i.e. by using two small precision races mounted behind the camera cup, then the greatest friction in your application is likely to come from the slip rings ( not a problem as far as I can see - a bit of friction will help damp the motion) ; Again keep the diameter of the slip rings as small as possible.
    Make the camera mounting cup from steel or brass (something heavy) then cut off the top half (or more) , since it does not need to be circular if it's not going to be a bearing surface.
    Bill
    Apr 2008
    59
    Hi Bill,
    Your solution looks good (very good!) but I can't utilise the back of the shell as a location point. Thats where the camera connects to the outside world. The cable connection is a series of concentric brass rings (total diam 18mm) which I need to mate onto with my pogo pins (see pics attached).
    The bearings will have to be mounted outside the circumference of the camera shell.... maybe.
    It might still be possible to do it like you describe if I extend the length of the camera internaly by the width of the required bearing. Have a look at the DXF I posted and you'll see the dilema I think.
    BTW I'm thinking of using tungsten (or a tungsten powder, epoxy mix) for the camera holder.
    Cheers!
    Apr 2008
    59
    Hi Bill,
    You were talking about slip rings... I would prefer to use a slip ring but I'm having trouble finding one sufficiently small. They're usually too big. Airflyte do one that 1/4" wide but 3/4" long. I'm going to contact them and see if they anything more suitable.
    Cheers!
    Apr 2008
    59
    Update.... this looks interesting...
    http://www.slipring.cn/products_LPSM.asp
    I have asked for a sample.
    Aug 2008
    573
    You weren't thinking of using that connector as the slip ring were you? It'll have for too much friction :horror:
    Too much friction will mean your picture twists several degrees before spinning back and probably overshooting - at which point your audience will throw up their lunch
    What's this for BTW? What kind of life expectancy?
    Is this a one off or short production run? I'm thinking, make a slip ring out of a set of small diameter brass tubes insulated with heat shrink (or press something into service like a multi-pole jack plug).
    Like this from CPC (UK)
    or this 2.5mm version.
    http://cpc.farnell.com/_/mp-425ln/2-...deg/dp/AV17491
    Bill
    Apr 2008
    59
    Hi Bill,
    I have PM'd you.
    Cheers!
    Oct 2007
    36
    I am missing something. Why not attach the camera to a length of square tube? Must it travel around corners? Does it need to react quickly? How far must it travel?
    Thanks for listening.
    Apr 2008
    59
    The camera is for pipe inspection so it has to go on a 90ft cable which has to go round pipe bends.
    Cheers!
    Oct 2007
    36
    Is this what you are trying to duplicate?
    http://www.southcoastequipment.com/i...ort=20a&page=1
    Thanks for the reply
    Apr 2008
    59
    Yes.
    I wouldn't say duplicate though. "Improve on" might be a better description.
    Cheers!
    May 2007
    767
    Have you considered using a simple shaft rotation sensor that is independent from the cammera. A simple weighted lever on the sensors shaft would then enable the vertical plain to be established. After all the view through this type of device equires skill to interpret the pictures which are circular. A superimosed arrow indicating top should suffice. The real problems start when the probe travels up a vertical run!
    The aim should be to keep the probe head as simple as possible. Rotating joints and slip rings would appear to be over complicating what could be a simple mental exercise or a software manipulation if you must have the picture rotated to display the image the right way up. Software manipulation will impose some time delay and you will need to consult with the computer buffs.
    Hope this helps you apply the KISS principle.
    Regards
    Pat
Page 1 of 2 12
  1. Thin aluminum bending
    By LaserImage in forum Bending, Forging, Extrusion...
    Last Post: 10-28-2008, 05:59 PM
  2. thin workholding
    By tonyaimer in forum Tormach Personal CNC Mill
    Last Post: 09-25-2008, 08:47 PM
  3. skate bearings versus linear bearings
    By paul langwade in forum Linear and Rotary Motion
    Last Post: 05-29-2006, 04:06 PM
  4. Double Bearings Or Quad Bearings?
    By ballscrewed in forum Mechanical Calculations/Engineering Design
    Last Post: 04-18-2006, 06:33 PM
  5. Bearings (Radial Ball Bearings)
    By The Bearing Man in forum Community Club House
    Last Post: 12-18-2005, 07:10 PM
