586,061 active members*
4,673 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Insert date and time in M post
Results 1 to 12 of 12
    Is there a way to automatically insert the date and time in the M post?
    John
    RE: Insert date and time in M post
    Add the line below.
    "(" {Date} " " {Time} ")"
    Darin Weatherbee
    CAMcad Technologies, Inc.
    Oct 2008
    50
    Not sure if this will help, but one way to get the date is to find the "SBackDoor Supressheader" line in your post and space it over, this will fill in your Company name, address and date. I did a custom setup sheet thru Surfcam and when I post a program all I need to do is hit "Create Setup Sheet" and paste it into my program. This was done by finding the SetupgenTXT.cfg file and altering it to your needs.
    PM your e-mail and I can send you what I have.
    Darinbee solution is what your really looking for, didnt see his post at the time.
    DANGER ZONE - HARD HAT REQUIRED!!!!
    Thank you for your help, date and time is working great.
    Where did you learn how to do this sort of thing? Some of these post edits seem rather simple once you know the language. Is there a bunch of info somewhere?
    John
    Jason, sending you a PM
    Jan 2008
    282
    Thank you all for help in adding date and time to the MPost
    I had never tried to do so but often thought it would be handy and it is.
    Lowell
    Oct 2008
    50
    Quote Originally Posted by John Welden View Post
    John
    Just got tired of waiting for my resellar to "fix" my post and started asking questions, eventually you try things on your own and figure things out.
    Jan 2008
    282
    I changed my M-Post as suggested as soon as I saw this thread. It has already proven helpful. It lets me see when a program was posted and if I have actually loaded a new one. Big help Thank you
    Lowell
    Contact your dealer and ask them for the Posthaste Manual or contact
    http://www.postprocessor.com/contact.html
    Darin
    Oct 2008
    50
    Quote Originally Posted by lkenney View Post
    Lowell
    Just remember to make a copy of your existing post before you make any changes, that way if something happens you still have a working post and dont make to many changes at once. Also you can customize your tool sheet too.
    P.S. I'm sure whatever changes you want to make to your post or setup sheets can easily be solved by members here, I also gave you my phone # and would gladly help you thru any changes you would like. I am not affiliated with any reseller or Surfcam just an everyday user for the last 14 yrs. that likes to make things better and easier to use.
    Jun 2008
    24
    Cool hmmmmm
    This doesn't work for me on m post
    I even tried - Replace "*" With "(" {Date} " " {Time} ")"
    StartCode # Start of the program
    %0
    O[Program#]
    $[0]
    ^[0]
    &[0]
    *[0]
    G00 G17 G40 G80 G90
    End
    changing to SbackDoor Header does add date and file name though
    Eddie D
    Pokeyboy Machine
    Hi, you all:
    If you want your copy of the Mpost manual, just hit F1 anywhere in the SURFCAM window, at left margin, see the content, and find Mpost, there is all the info you need.
    Kid regards, Mario
    Jul 2005
    42
    date and time was cool it worked very good
  1. acramatic 2100,reseting time-date
    By lineborn in forum Cincinnati CNC
    Last Post: 06-12-2009, 04:41 PM
  2. Anyone know how to set the date and time on a T32-2 controller?
    By mattme in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-29-2008, 10:49 PM
  3. Date and Time Variables?
    By broby in forum Okuma
    Last Post: 12-11-2007, 11:12 PM
  4. How to set the time and date
    By DomB in forum Haas Mills
    Last Post: 03-11-2007, 12:03 AM
  5. Mazak 640t time and date set?
    By CHEEVES in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-13-2006, 02:45 AM
