586,061 active members*
4,423 visitors online*
Page 10 of 12 89101112
Results 181 to 200 of 228
  1. #181
    Dec 2007
    98
    Smile DXF Tool-path Sorting............Problem solved.
    Quote Originally Posted by WayneHill View Post
    Bhavic,
    Can you post the code program you are trying to convert?
    Problem solved, but it took two programs at the cost of about $100.
    First I had to get a newer version of CorelDRAW to import my DXF file into.
    Secondly I bought a Corel add-on called "Artwork Optimizier for CorelDRAW Standard Edition"
    Corel now Exports sorted DXF files that cuts down the traverse time of the cutting tool substantially.
    Rolf
  2. #182
    Mar 2004
    761
    Rolf,
    Good to hear!
    Wayne Hill
  3. #183
    Mar 2004
    761
    scbauml,
    Can you post the CNC code that is not working? It could be a formatting type the software does not work with.
    Wayne
  4. #184
    Jul 2011
    semi circle drawing problem
    HIII
    i am working with vb6 & drawing the semi circle with Circle command in vb6 on picturebox which is drawn fine
    My problem is that the endpoints are coincided with the points where i have made selection & given command to draw a semi circle
    So how can i coincide the points
    Second problem is when i m saving the semi circle in dxf format & when view in it it is shown as a polygon with 10 points connected with line
    Similarly when i zoom in the endpoints are not connected with the start ^& end point of line which is selected
    how can i overcome the problem
    Pls any body help is appreciated
  5. #185
    Mar 2004
    761
    It could be a default setting of autocad that defines the graphic circle tolerance.
    QUOTE=bhavik;989877]HIII
    Pls any body help is appreciated[/QUOTE]
    Wayne Hill
  6. #186
    Jul 2011
    how to change the LSTYLE
    HIIIIII
    I have thew problem in setting the lineStyle i.e DAshed & continous
    I m using VB6 & opening the DXF file & saving in DXF format
    But I m unble to set LSTYLE to Dashed & Again reset to Continus or solid lines
    Since i have toi distinguish my object with diffent lines But i m unable to do so since the LSTYLE is set in header section
    I want it to be change in when & were required 3
    How can i do this
    Pls help is appriciated
    Another case is of displaying Filled circle How can i stored information tat thecircle is fiiled with suppose Yellow color
    Can this be possible
    Pls help
  7. #187
    Oct 2011
    i need help whit this converter
    Hello Wayne,
    I need help because i only have file .nc and the program not accept this tipe of file. Exist any mode to convert .nc to .dxf?
    thanks you,
    Jorge Ventoso
  8. #188
    Mar 2004
    761
    Just rename the file to TXT extension.
    Wayne Hill
  9. #189
    Dec 2011
    Only G1 ?
    Thanks Joe. Now you can rotate or scale the code as you like. :banana:
    Wayne
    Hello Mister Hill,
    I search for the same application but with only the G1 deplacement, it is posssible ??
    thank you very much for your answer.
    Mat
  10. #190
    Mar 2004
    761
    Hello Mat,
    I sell a newer version on my web site. See my Sig link below.
    Thank you,
    Wayne
    Wayne Hill
  11. #191
    Sep 2005
    371
    Hello Mat,
    Thank you,
    Wayne
    Web site has either been sold, hacked or something. All I see is a lady and I'm not fluent in the language presented.
  12. #192
    Mar 2004
    761
    Hello Mat,
    Thank you for letting me know about this. My Web Host has been hacked for a third time. I am getting sick of this.
    Grrrrrrr....
    Wayne
    Wayne Hill
  13. #193
    Mar 2004
    761
    Mat,
    This is what I think happened. My web site was registered as
    codemangler.com
    www in front of it defaulted to my web site. Something happen on the internet where www class of web site can be used as another web site. So I guess I lost the WWW in front of my web site... Grrrrrrr
    Thank you for the information.
    See my web site at
    codemangler.com
    Wayne
    Wayne Hill
  14. #194
    Jan 2010
    2141
    Mat,
    codemangler.com
    See my web site at
    codemangler.com
    Wayne
    Where is your web hosting handled?
    Most likely either your DNS record has been hijacked or someone tampered with your server's configuration.
    It should be possible to get it fixed - if not by your hosting company, then by changing to a different hosting company.
  15. #195
    Mar 2004
    761
    DoorKnob:
    It is hosted at Portal Home - iamyourhost.com.
    They admit they had been hacked through a software flaw in a cart program on the host. It was nothing that I had done to expose any weakness on my web site.
    Time to search for a secure web host...
    Wayne Hill
  16. #196
    Dec 2005
    594
    Wayne,
    For your web site, log in only via ssh and only use sftp to transfer your files. Telnet and ftp broadcast your username and password in clear text, where ssh and sftp are encrypted. Login to your host via ssh and change your password.
    Mark
  17. #197
    Sep 2005
    371
    FYI,
    Either you've been hosed again or you've made some changes.
    The images aren't there, the "More Informaton" link and the "Purchase" like yields a HTTP-404 error.
    Vogavt
  18. #198
    Mar 2004
    761
    Vogavt,
    I hosed my own website this time! It's back up.
    The web host said the hacker installed hidden directories on the site that launched the other web site. I will be rotating my password more often. It was a php flaw that was allowed access to several web account on the host.
    Thank you,
    Wayne
    Wayne Hill
  19. #199
    Sep 2005
    371
    From your website:
    The Z Low and Z High will filter out Z data within that range. This will be very handy when you need just the top level data on a GCode program.
    I'm confused. Seems like you would want to exclude anything outisde of the upper and lower limits. Did you intend to say "The Z Low and Z High will filter out Z data not within that range."?
    or maybe
    Setting the Z Low and Z High parameters will only show the Z data within that range, i.e., excluding all other data. This will be very handy when you need just the top level data on a GCode program or data from a particular range of Z height.
  20. #200
    Mar 2004
    761
    The Z filter will keep the Z positions within the Min/Max of the settings. The website will be updated to clear up this statment.
    W
    Quote Originally Posted by Vogavt View Post
    From your website:
    or maybe
    Wayne Hill
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  3. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum News Announcements
    Last Post: 12-19-2012, 04:37 AM
  4. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
