586,103 active members*
3,337 visitors online*
    nema 23 vs nema 34. how much power do I need?
    I'm building a small lathe. 5c headstock, 4" swing over slide, 8" swing over bed. About 12" Z and 10" X (gang tooling). Z ballscrew is 16mm 4mm/rev. Z ballscrew is 16mm 2.5mm/rev. I'm planning on direct driving the screws. Hoping to machine everything including tool steel. Also down the road I'm considering adding a stepper/servo to control the spindle and live tooling.
    I have been planning on steppers because I'm scared of servos but it seems keling and others offer reasonably priced servos.
    The big question is should I build for nema 23 or nema 34 motors? Nema 23 would be easier to package but its not a huge problem either way.
    Will
    Jul 2007
    887
    Do you have any ballpark figures on how much force you need and how fast you want the machine to move?
    If you, as an example, look at the speed/torque curve of Kelings NEMA23, 425oz-in motor (KL23H286-20-8B) the chart shows that you'll get roughly 1Nm at 2250 half-steps/second or ~340rpm.
    Directdriving a 4mm pitch screw with a motor delivering 1Nm of torque will give you a linear force of 1Nm/(0.004m/2/PI)=1570N not counting frictionlosses etc but let's be conservative and say 1000N. That's 1000N (225lbs) of linear force at 1360mm/min (~50ipm)feedrate, at 600mm/min you'll get roughly twice that.
    As for the rapids....at 5000 halfsteps/second (3000mm/min) you still get 0.5Nm of torque which gives you 785N of force. Lets say that the friction etc still "eats" 570N and you have 215N left.
    The chart shows the drive being fed with 30V which to me sounds awfully low for a motor rated at 4.17V. Raising the voltage to 60V should give you a conciderable boost in high speed performance and allow you rougly double the rapid speeds calculated above.
    /Henrik.
    Oct 2005
    225
    If you have a servo motor do you use the continuos torque or the max torque for the calculations and then would you multiply times gear ratio for the drive pulleys on the servo system?
    Example motor http://www.kelinginc.net/K23-120-36.pdf
    Tommy
    Mar 2006
    2712
    IMHO continuous torque. I believe if you apply max torque the drives will "kick out". Some we've done will not even allow you to reach max and will shut down to avoid damage.
    Gear ratio X continuous torque X efficiency
    EX. 3:1 X 100 Nm X 90% = 270 Nm
    Dick Z
    DZASTR
    Quote Originally Posted by H.O View Post
    /Henrik.
    Thanks for the math. That chart is for the Nema 23 286 oz stepper. The Nema 23 steppers go up to 570 which seems like it should be plenty.
  1. Nema 23 Or 34?
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 04-05-2021, 07:00 AM
  2. nema 34 1600 oz or nema 42 3200 oz?
    By 15mgtar in forum Stepper Motors / Drives
    Last Post: 07-27-2009, 11:53 PM
  3. Buy NEMA 23 270 OZ-IN
    By jhonniewalk in forum Stepper Motors / Drives
    Last Post: 07-10-2009, 10:44 AM
  4. Power supply and Nema 17
    By woodturn in forum Stepper Motors / Drives
    Last Post: 02-13-2007, 05:11 PM
  5. Standard Nema 34's vs Nema 34's with encoder/controller.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-16-2006, 05:03 PM
