having a problem with profile milling and would like to know if there are plans to fix with a future upgrade?
i am profiling a part using g41 cutter comp and a circular lead in and out. my problem is that using circular lead the program generates a straight move before the 90 degree circular move. alot of the time these two moves put you starting on the part and will crash.
i want to know if there are plans to be able to control the straight line move before the circular moving and also to be able to control how much of an arc to use, like 45 degrees or various angles. this mod alone would greatly increase the the way users are having to get a good start point for profile milling with cutter comp and circular leads without having to draw extra geometry to compensate for this problem.
any input would be greatly appreciated.
