586,103 active members*
3,703 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > bobcad mach3 question
    Sep 2005
    72
    i have been useing mach 3 for a couple of years now with my autcad drawings. when i import autocad dxf files into lazycam it always puts my tool starting at the bottom left of my drawing so i know where to make my fixture set up . when. i load a gcode file from bobcad version 23 the tool always ends up in a different starting place .how do i fix this ?
    thanks alex
    Feb 2009
    2143
    Alex, not sure I follow your question, but try this. Make sure you position your drawing over X0 Y0 in BobCAD. The CAM side will key off of the axes for position, so if you draw them "way out in space", you better have a big table to take that in to account!
    For the Z axis, you define the heights in the CAM tool you right. Inside the tool (pocket, Z level, whatever 2 or 3D tool you select), you choose the Material Height in the first setting. You don't have to follow the model on this one. If you want to set the top of your part at 0, select 0 here. If you want it to be at 1" on the mill, put in 1. Also select the clearance from that height for your rapids - this could be important if you are using clamps, but usually I just use .1" to clear the part.
    Finally, when on your mill, you need to set the tool at 0,0,0 on the part (with respect to what you entered in BobCAD), and rezero all axes. Then you should ALSO (in my experience) select "Ref All Home", and rezero them again. If you don't do that, you might find the tool diving in to the material! (don't ask how I know).
    Hope that is enough to get you moving along, post up further questions if needed.
    Sep 2005
    72
    thanks for the reply! i will give it a go tonight an post you back on my progress.
    thanks alex
  1. BOBCAD V23 Code for Mach3
    By adel_acameron in forum Mach Mill
    Last Post: 03-22-2009, 09:25 PM
  2. BobCad v22 cutterpaths that MACH3 doesn't like??!
    By hodge98ws6 in forum BobCad-Cam
    Last Post: 07-05-2008, 04:02 AM
  3. Bobcad for Mach3 post processors
    By duraflap in forum BobCad-Cam
    Last Post: 10-28-2007, 03:16 PM
  4. Mach3 / Bobcad V21 file help
    By Dfennell in forum Mach Mill
    Last Post: 03-25-2007, 06:48 PM
  5. BobCAD/CAM V21 and Mach3 Postprocessor
    By southernexplore in forum BobCad-Cam
    Last Post: 07-25-2006, 06:28 AM
