To not fill up C1's thread... I appear to be having a problem with my machine. I am getting times where the X just loses steps this way or that way.
My X is driven on both sides by the R&P drives. At first I thought it was the steppers overheating, but I managed to get fans on them and keep the temperatures down, so I don't think it's that.
I tightened up the bearing blocks where there was a little slack (some bearings not hitting and spinning as it moved). With power off I have moved the X back and forth and feel nothing catching.
With power on, I can't move the X, no play at all that I can tell.
So what else might it be? Controller? Mach 3 settings? Not sure where to progress on this one.
Most of the stuff I have been cutting in the past has been 3D gcode that just moves the y back and forth, and the x slowly increasing as it moves over the part, so perahaps I have always had the problem and just never cut much to notice it, or maybe it's a newer issue.
Any suggestions on what to check or look at would be appreciated.
