586,089 active members*
3,835 visitors online*
Page 30 of 34 202829303132
Results 581 to 600 of 676
  1. #581
    Jan 2008
    932
    Received the dymondwood, thanks. Was away since thursday, son's high school marching band was at states, and I was there to help out and watch as well. 8th in state, highest score they have had, first time in finals and highest placement. Was a fun but draining weekend.
    Wood neophyte.
  2. #582
    Dec 2004
    783
    No problem it weighs a good bit more than the same size chunk of birch ply huh?
  3. #583
    Jan 2008
    932
    Haven't been out to the shed in a bit, been occupied by work and in the house stuff. Still waiting the list of names from the marching band director to continue with that project. Would have thought it wasn't hard to email a list of names.
    Wood neophyte.
  4. #584
    Jan 2008
    932
    I have long been working on some pistol grips for a friend. They are close, but my 'issue' seems to be doing 2 sided, and not getting the flip lined up quite right. So I drill my spoil board for pins, and the stock to be cut get's the same holes. This allows an equal flip no matter the width of the stock. I set it up to have x and y 0 at the center of the piece, and came to realize I wasn't getting that perfect either. So I made the below 'tool' to help. Now I have a file that cuts the peg holes in the spoil board and one in the center. I slip this piece in the center hole and use the |<-X->| and |<-Y->| in the probe tool to set x and y at a correct zero, then peg and clamp down the stock and cut.
    Wood neophyte.
  5. #585
    Dec 2004
    783
    Interesting, have you seen this thread? http://www.cnczone.com/forums/showthread.php?t=192432
    I don't do any high production 2 sided stuff, so I usually just mill pockets the parts fit tight into to finish the back side, this way I know the placement in all 3 axes is spot on.
  6. #586
    Jan 2008
    932
    No, I had not seen that, it's slick. Thanks for pointing it out.
    Wood neophyte.
  7. #587
    Jan 2008
    932
    Well dammit! I finally got all the names for my project for the marching band. Got all set up, started to cut… Y went way off.
    Stopped it, figured I could just use the other side… slowed things down (feed) and started again, same thing. Ugh. A 65 dollar piece of cherry wasted….
    Investigated the machine as I was mad and sad (as this was going to be presented saturday, now no way).. did some g0y20, g0y0's, back and forth, then saw the y slip… turns out the screw on the coupling on the stepper had backed out so the stepper shaft was slipping in the coupler. ARGH!
    Fixed that, threw down a 24x48 piece of MDF to run it again to ensure that was all that was wrong, half way through the cut is great.
    Now if only I was lucky enough to find a good piece of wood that was 24x40" early tomorrow, but I know that's not gonna happen.
    Wood neophyte.
  8. #588
    Apr 2007
    8082
    Bummer, for sure. It's those shop gremlins hiding over in the dark corner of the room.
    CarveOne
    http://www.carveonecncwoodcraft.com
  9. #589
    Jan 2008
    932
    Found out the corian will be in this coming week. Will be nice to get it and get this project done.
    I the mean time I bought some of the metallic paints that actually have metal in them, and can be patinaed. Cutting an old school v carve myan calendar from MDF and will prime then use the copper paint, then patina a bit to see how good it comes out.
    Wood neophyte.
  10. #590
    Jan 2008
    932
    Attachment 210130
    This is some of the sophisticated finishes, copper, with green patina. Put too much patina on first go and had to brush on a light coat of copper on the flats to get it to look a little more like I wanted. Not bad, no doubt a bit to learn on the techniques for using the stuff.
    Wood neophyte.
  11. #591
    Dec 2012
    78
    Hey arbo I'm about finished painting the steel rails. I was wondering what do you put on the bare metal to keep it from rusting? I have a bottle of bostik topcoat, should I use something like this? Using oil would it accumulate dust and maybe make the bearing stick?
  12. #592
    Dec 2004
    783
    Quote Originally Posted by Jerseydog View Post
    I used to use silicone spray on a rag to clean the bare steel and keep it from rusting but switched to Eezox recently and it works much better. It's a dry lube/cleaner for firearms that is probably the best anti corrosion coating available that doesn't attract dust.
  13. #593
    Dec 2012
    78
    Quote Originally Posted by Dylwad View Post
    I just bought a 3oz bottle of eezox and was wondering how do you apply it? I know it has to go on the bare metal but will it peel the paint? Should i just use a rag to apply it to metal. Thanks for your response.
  14. #594
    Dec 2004
    783
    I just use a small rag or patch, the solvent in it might hurt the paint, so be careful. A little goes a long way. Wear gloves, it's stinky stuff.
  15. #595
    Jan 2008
    932
    Since I live in Colorado where it's dry (we average under 20% humidity in the winter), and dries quick, I haven't put anything on it. So far not a bit of rust.
    Wood neophyte.
  16. #596
    Dec 2012
    78
    Hey arbo I want to start building my z-axis. What size should i get the 1530 piece? Where did you get the parts to build it? I have next week off and will like to order all the parts to work on it during the week. Thanks for your help.
  17. #597
    Feb 2011
    Has anyone tried gun blue used on steel gun barrels? It completely prevents corrosion and lasts for a few lifetimes.
  18. #598
    Jan 2008
    932
    Oh, long time since I checked this thread, sorry. Jerseydog, depends on z movement desired. Mine is built with the c&c router parts stuff.
    I finally picked up the big piece of corian material for the high school band project of mine. Cut it yesterday, sprayed it this morning, then some sanding. Need to clean out the lettering better, then clear coat. Then epoxy on some wood on the back as a hanger for it.
    Wood neophyte.
  19. #599
    A better choice is a good quality silicone sealant. That's what's used to fasten Corian counter tops to their substrates. Corian expands and contracts quite a bit with temperature changes, and wood expands quite a bit with changes in humidity. Both of these will cause an epoxy bond to fail over time. Silicone allows both to move quite freely, and it sticks really well to just about everything. Just put a big dab every 6-8".
  20. #600
    Jan 2008
    932
    Well, too late for that, as I didn't see this post and it is delivered.
    Wood neophyte.
  1. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
  4. Replies: 0
    Last Post: 10-27-2009, 08:25 PM
  5. Milling - Need 90" X 24"+ X 1" in alum - in NW area
    By ChinookR&D in forum Employment Opportunity
    Last Post: 04-15-2009, 12:46 AM
