586,067 active members*
5,399 visitors online*
Page 34 of 34 24323334
Results 661 to 676 of 676
  1. #661
    Jan 2008
    932
    Re: 24" x 80" cut area, 8020 build...
    Have the new PC up and running. Installed Mach 3 from the original DL I had, so it put things in the registry properly, then just copied over the whole directory from my backup. Everything seems to be working nicely.
    Now I have loads more space in that corner. Which is important as my shed is small.
    The old bigger monitor used to sit on that triangle of wood where the kb now is, along with all my bits and such. There was a shelf just below it where the kb and mouse were. And the old PC took up that whole stand the new pc is on. So I can and will cut that back and make it smaller.
    Wood neophyte.
  2. #662
    Jan 2008
    932
    cleaned up and about ready to get busy.
    And first test part from corian molds I cut. Testing epoxies and paints to see what works well together.
    Wood neophyte.
  3. #663
    Jan 2008
    932
    Cutting out fuse halves to glue together to make a fuse plug for a little composite glider.
    MDF spoiler held down and part to cut attached with spray glue. Then rough and finish and wa-la, half a fuse. Will centers then glue together so I have a center line when sanding. Also will soak with epoxy.
    Wood neophyte.
  4. #664
    Jan 2008
    932
    Fuse halves pinned together. They got loads of epoxy which was soaked in with a heat gun.
    Also roughed the nose cone plugs and coated with epoxy the same. Once that's cured I go back and run the finishing pass.
    Attached Thumbnails Attached Thumbnails d09e8285-9bcf-4734-9dec-b88210029ff4.jpg   a223637f-255d-44d4-93ba-c0087d0381f6.jpg
    Wood neophyte.
  5. #665
    Jan 2008
    932
    cutting the fuse plug for the 60" version.
    Attached Thumbnails Attached Thumbnails e379ed3e-a07f-47c6-a02e-365bbe9d9d6c.jpg
    Wood neophyte.
  6. #666
    Did you get the Edit G-code button working?
  7. #667
    Jan 2008
    932
    Yeah, was on that config page. I swear I looked there before and just didn't see it. Must be that getting old thing. Thanks.
    Wood neophyte.
  8. #668
    Dec 2012
    78
    Arbo
    What material are you using to make fuselage? It looks like MDF.
    Sent from my SM-N900T using Tapatalk
  9. #669
    Jan 2008
    932
    Yeah, it's MDF. I will glue up the halves, make sure it is straight, then will mix up some think epoxy and wipe it on. Then you hit it with a heat gun and the MDF just soaks it up like a sponge. Keep doing that till it doesn't take any more. It gives it a hard shell to sand down to 3000 grit and polish. Then I use that to make a mold.
    Here is the fuse for the 60" along with two for the 40" that I made...
    Gerry, never noticed that joint cam you made, shows how well I pay attention to tag lines. Cool stuff. What sort of bits you use for the joints that are angled in?
    Wood neophyte.
  10. #670
    Dec 2012
    78
    Can you document every step because it's a project that I will like to work on in the future.
  11. #671
    Jan 2008
    932
    I can try. I guess I should maybe start a thread in the model sub forum here at the bottom? Nah, that's like work...
    LOL
    Wood neophyte.
  12. #672
    Dec 2012
    78
    You don't need every step but it will help.😊
  13. #673
    Jan 2008
    932
    Will try to keep it up to date here: http://www.cnczone.com/forums/parts-...ml#post1887592
    Made new thread.
    Wood neophyte.
  14. #674
    Quote Originally Posted by Arbo View Post
    Dovetail bits.
  15. #675
    Jan 2008
    932
    Dovetail bits.
    DOH. slow brain on me.
    In other news, I managed to pick up an old 4 axis hot wire machine. I built the electronics long ago, but gonna update them. And eventually will update the mechanicals as well. Think I might get a few carriages and attach cross members, put them at the end of my machine so I can move them out of the way, and then position them when I want to use them, as you sometimes need to change distance between them depending on the sweep of a cut you are doing.
    Wood neophyte.
  16. #676
    Jan 2008
    932
    Put down new mdf for the spoilboard and planed it down level.
    Attached Thumbnails Attached Thumbnails f05a1de9-af77-4fcf-b8df-0f2da258debb.jpg
    Wood neophyte.
  1. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
  4. Replies: 0
    Last Post: 10-27-2009, 08:25 PM
  5. Milling - Need 90" X 24"+ X 1" in alum - in NW area
    By ChinookR&D in forum Employment Opportunity
    Last Post: 04-15-2009, 12:46 AM
