586,069 active members*
3,410 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Rockcliff 4 axis controller with only 2 axis in use
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Aug 2009
    146
    Hi Jeff,
    Been a long time since I made contact. Well, the project is finally finished and operational, thanks to your help. I am here to tell you that it was greatly appreciated. I'm involved in some deeper aspects of design and programming of Mach3. I am currently working at attaching a commercial thread break detector that is basically an optical relay with 5 volt inputs and a spring activated ceramic coated thread tensioner that will input a voltage to pin 15 on the Rockcliff board. What I don't understand is the power supply to it. I have to work on that though. Take care buddy, I'll post some photos of the system in operation real soon.
    Larry
    W4LML 20mtrs
  2. #22
    Feb 2007
    4553
    Post
    Larry,
    Please post a link to the schematic for the thread break sensor.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  3. #23
    Aug 2009
    146
    Quote Originally Posted by jalessi View Post
    Larry,
    Jeff...
    Hi Jeff,
    here is the schematic.
    Larry
    W4LML 20mtrs
  4. #24
    Feb 2007
    4553
    Post
    Larry,
    I would suggest connecting the sensor to your breakout board in PNP mode.
    Simply provide a D.C. power source (15 to 30 volts d.c.) to the sensor also connect ground (black) to the BOB ground then connect the green from the sensor to an available input on the BOB.
    Jeff...
  5. #25
    Aug 2009
    146
    TB Detector
    Hi Jeff,
    I was basically of the same opinion, but, you know how it is, better to measure twice and cut once, eh? Sure appreciate the opine.
    Larry
    W4LML 20mtrs
  6. #26
    Aug 2009
    146
    Re: Rockcliff 4 axis controller with only 2 axis in use
    Hi Jeff,
    Long time no talk to. I have an issue. I blew out the magic smoke on my rock cliff 4 axis board, and I find out I can't get a new one. The only thing available from Rockliff is a 5 axis controller interface board. Looks like the pin outs are same, b ut my question is this. Will the flood/mist relay require an optical relay the same way as the rock cliff 4 axis board? Also, is there anything special that needs to be done to setup the Estop, or is it the same as the 4 axis board also?
    Larry
    W4LML 20mtrs
Page 2 of 2 12
  1. I need a 4 axis mill and 3 axis lathe controller dynamotion + kflops?
    By charlieslasher in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-28-2014, 01:40 AM
  2. 3 axis CNC controller kit 3 NEMA17 78 oz-in stepper motor + 3 axis CNC board
    By Chaparro1973 in forum Stepper Motors / Drives
    Last Post: 03-12-2012, 10:26 AM
  3. Rookie Question...3 axis vs 4 axis controller
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 09-14-2009, 02:04 AM
  4. Rockcliff to 5-Axis
    By GeneralMayhem in forum DIY CNC Router Table Machines
    Last Post: 12-03-2008, 11:33 AM
  5. 4 axis controller for 3 axis machine?
    By tybrenis in forum Community Club House
    Last Post: 01-20-2007, 04:12 AM
