Originally Posted by
LakesideMachine
......Anyone know how to tighten up the hug right off the shuttle servo? Its a slip clutch type system, but seems to be able to float out and cause trouble now and then.....any help??
Are you sure it is a slip clutch and servo? My VF0 just has a simple gearmotor driving a crank arm, the same as my MiniMills and VF2s.
I have had problems on a MiniMill with the crank arm coming loose and moving out so it hit the housing but that was easily fixed by pushing it back and tightening the setscrew.
