586,058 active members*
3,712 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How to change voltage on a Fanuc 6m
    Jun 2006
    40
    Hi
    I am actualing burning up an Amada Coma punching machine with the fanuc 6m cnc controller.
    I need to change the working voltage between 400Volt (european) to the 200Volt (South America)
    On the instruction manual and electrical drawings it seems possible.
    In fact the electric motor on the puncher has the dual voltage 400 or 220Volt and there is also a little trafo with the possibility to change between 400 and 200.
    Now i have the problem with the electronic system because in the drawings all the power units of fanuc are inserted on a NC UNIT but there are no instructions on how to change the voltage.
    I opened all the doors of the cabinet and there are two transformers, one big with 5Kva power for the X Y and turret axis controls and another one on the back panel, near the power unit model a06b 6042 c013 with all the voltage between 200 and 580Volts.
    Can anybody help me to find the right way to change, if there is the necessity of the voltage on this trafo.
    Is this the only one i need to change?
    Hope to have an answer as soon as possible
    Have a nice day
    24221
    I have no information on Amada with 6P, but if you refer to the electrical drawings it should explain, you will only need to change the transformers that have 440 supply to them, any other transformers that are fed from the secondary of these transformers do not need to be changed.
    If there are other unmarked transformers connected to the 440, and they have input taps then you may need to find out by using a meter by voltage check to find out the 220v input, if they have one.
    Check the schematics for any other circuits connected to 440v, I would not expect a great deal apart from the transformers.
    Al.
    Albert E.
  1. fanuc OM high voltage alarm
    By maxvic in forum Fanuc
    Last Post: 07-01-2009, 05:07 AM
  2. Fanuc DC servo, what voltage?
    By Jonne in forum Fanuc
    Last Post: 09-21-2007, 03:27 PM
  3. Effects of voltage change?
    By cnczoner in forum Stepper Motors / Drives
    Last Post: 06-25-2007, 03:47 PM
  4. change analog output voltage
    By Karl_T in forum CamSoft Products
    Last Post: 12-21-2005, 03:03 AM
