I’ve been trying to design a bench top mill using a steel beam and column as I have a little welding experience and steel is relatively cheap. Also I read somewhere on this forum that many mills with linear bearings are overbuilt as the larger bearings are what’s available cheap on the secondhand market so why not! However there doesn’t seem to be much available where I am so I thought I’d design a monorail version to try and cut costs. I’m just not entirely sure one lineal bearing on each axis is up to the job. I’ll be doing mostly small work which I can centre over the bearing and the largest work will be engraving circuit boards and electronic face plates which wouldn’t place a lot of stress on the edges of the mill table (500 x 200mm).
Can anyone tell me whether this design is ok?
Any help appreciated. PS sorry for the image. I cant seem to get it sharp.
The bearings specs are:
Abba BRH25A
Lmax 4000
G 1950
Dynamic(C) 1950
Static(CO) 3200
Mx 36.8
My 22.8
Mz 22.8
Block(kgf) 3.6
