586,589 active members*
2,462 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Treadmill 2hp dc motors, were they go?
Results 1 to 12 of 12
    Aug 2005
    828
    Any one know of a site that still sells the ~2hp 90vdc treadmill motors? I have seen them on eBay and other sites for years, now don't see any.
    Dennis
    Feb 2007
    4553
    Unhappy
    DennisCNC,
    Surplus Center had thousands of them, they have been sold out for several months now.
    https://www.surpluscenter.com/home.asp
    Sorry to pass along bad news.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Oct 2008
    116
    I was looking for some at the beginning of the summer and had the same results you did. Maybe the copper inside was worth more than the surplus price?
    BobH
    Aug 2005
    828
    I contacted a company in china about them, but seems they want to sell a container load of them only.....
    Dennis
    Aug 2007
    67
    another option
    It seems they are all going to wind generators. I see alot of those being sold for windmills.
    I can give you a model number (M-220686) of the one I bought to replace the one I burned up like yours. I found it on Ebay and it doesnt have a manufacture name. It's from a treadmill like the others but that's all the info I can find. This thing has awesome power but the rpms are lower so I am going to have to change my pulley system. I can drive a .875 spade thru 3/4" aluminum at about 4-1/2 IPM. The mount also has a wider spread on the bolt holes but easy enough to overcome. Hope this helps you and if anyone can find the maker please pass it on.
    Bruce
    24223
    Over the years there have been many 'Treadmill' motors sold of various types, usually surplus after a Treadmill manufacturer go out of business in that highly competitive market, The only one I found that had quality was one made by Baldor.
    You are probably better off to look for something like an older DC brushed servo motor such as Getty's or similar make, the ones with the Fanuc or Mitsubishi label on them usually ask too much, I have got nice large DC servo's with Tach and encoder for ~$50.00 on ebay at different times.
    The Tach allows for tight rpm control with KB or Baldor SCR controllers.
    I can imagine what quality the R.O.C. motors are, if their AC motors are anything to go by, when you come to need replacement brushes, good luck.
    Al.
    Albert E.
    "Treadmill motors" appeared on surplus sites after the personal exercise equipment market bubble went bust. All those excess motors passed through the system and are long gone now. They were sold at a loss and there won't be anymore because it was a one-time thing. I talked to some people from companies that took a bath ($$$) on dumping those motors.
    Mariss
    Apr 2004
    305
    Go on craigslist and pick up a treadmill for free - $25. I got one a couple of weeks ago in great shape. It actually had a baldor motor on it and was fully functional. So I got the drive to boot. All for ten bucks. And I just had to go and get it, 15 minutes away.
    That motor is going on my old collet lathe. I had planned on using a freq drive to run the three phase motor, but I have experienced problems with electrical noise coming off the VFD and wrecking havac with the pulse stream going to the stepper drives on my mill.
    Aug 2005
    828
    I'm looking for constant supply of this type and size of motor. Any ideas on what local manufacturers might make them?
    Dennis
    24223
    The Universal motor can be used on AC & DC also, these are used in routers and hand tools etc.
    But for P.M. shunt DC motors, I don't think their are many US manufacturers left, Baldor still sell them I believe, but you won't get them for Surplus prices.
    Al.
    Albert E.
    Apr 2006
    158
    Quote Originally Posted by DennisCNC View Post
    Pacific Science also made these motors: http://www.pacsci.com/
    Also Magnatek made some.
    Aug 2005
    828
    What do you know, Amazon sells them...
    Dennis
  1. 7x treadmill motor and speed controller conversion
    By maxboostbusa in forum Mini Lathe
    Last Post: 01-15-2014, 11:28 PM
  2. MC-70AW treadmill controller
    By tpworks in forum CNC Machine Related Electronics
    Last Post: 09-18-2010, 04:00 AM
  3. ged's treadmill spindle
    By ged in forum DIY CNC Router Table Machines
    Last Post: 10-22-2007, 04:58 AM
  4. 4 wire treadmill motor ????
    By whiteriver in forum CNC Machine Related Electronics
    Last Post: 04-30-2006, 02:16 AM
  5. Easy heatsink for Hot treadmill motors
    By rc-cellar in forum Benchtop Machines
    Last Post: 10-30-2005, 05:10 AM
