586,100 active members*
2,680 visitors online*
Results 1 to 6 of 6
    Jul 2003
    86
    DaeWoo Lynx 200 GL
    this machine has the Fanuc 21iT control
    My problem is i can't get the spindle to orintate to a specific deg.
    the m19 work for the set pramater of 0
    the C30. does not work or the H30 (samples) of what i have tried.
    thanks
    FORD = First On Race DAy
    Apr 2004
    18
    You probably would code it like this:
    M19S1000;
    The S code is decimal degrees so in the example S1000 = 1 degree. Yes, use S.
    Furthermore: Parameter 4034 S1 controls the orientation position of the main or in other words sets where the M19 will position the spindle in rotation. It is a value where 11.3 = ~one degree. On machines equipped with sub-spindles, S3 controls the position of the sub and yes S2 controls live tools. Typically when matching sub to main, main is left alone and sub brought to it. Daewoo will tell you to leave the main orientation alone because in most cases the M19 position and C0 are set to the same orientation. M19 (and M119 for sub) are meant to be used with external loaders such as a gantry to match hand orientation etc.
    Hope this helps.
    Experience is what you get when you don't get what you want.
    Jul 2003
    86
    Will after 4 phone calls and 8 different reps i got an answer.
    It was so simple and not in the manuals.
    90 degs = S900
    so my problem was i did not know that it need to be three places for the
    angle that i needed 62.5 degs = S625
    M05
    M19S625
    worked just like i was told it should
    Nov 2004
    3028
    Next time call Casper Zweiffel at the West Caldwell, NJ office. He is an excellent applications engineer with Daewoo.
    George
    Jul 2003
    86
    Quote Originally Posted by machintek
    I will be calling him in the AM, thanks George
    fjd
    Jun 2005
    54
    George
    I was lucky when my company bought their Daewoo... Kaspar was the one that trained me on the machine. And being in his 70's, he is sharp as a tack. That man is amazing! He knows the Fanuc book inside and out, and he knows the Daewoo turning machines the same way. If you ever have a programing question or concern, he will know how to help you...
    Kaspar Rules!
    ~Tony~
  1. New To Daewoo..... Any Others
    By rolinjunk in forum Daewoo/Doosan
    Last Post: 02-16-2009, 11:05 PM
  2. Daewoo Lathe feedback
    By Gunner in forum Daewoo/Doosan
    Last Post: 07-26-2005, 09:08 PM
  3. Daewoo Lathe Post Help
    By MONKEYBOY621 in forum Post Processors for MC
    Last Post: 02-25-2005, 01:34 PM
  4. OneCNC's $100,000 Gift To 200 members of the CNC Zone.
    By cncadmin in forum News Announcements
    Last Post: 12-17-2004, 08:04 PM
  5. 200 Oz-In 6.5 Amp Bipolar Parallel
    By motomitch1 in forum CNC Machine Related Electronics
    Last Post: 05-06-2003, 08:07 PM
