Originally Posted by
sdjdave
I have a copyright on a design that I want stamped as a lapel pin. I am currently having the dies made, and need a US company to stamp them.
The pin will be stamped from 0.0625" brass and will measure 0.5" X 0.75". It will then have a tie tac pin fusion welded on before we send it out for gold plating. I will supply the stamping and trim dies. You will be responsible for delivering clean parts ready for assembly and plating. If you have automatic capacity, I will need to know what type of machine you have so I can get the dies set up to run on your machine.
This job has the potential of several hundred thousand pieces, so both of us can potentially make some money here. This pin is a political pin, and the people buying it will all be Americans, so I want all the work done here in America. Sorry to all of our global friends out there, but America has some problems that we have to address ourselves, and one of those is keeping some manufacturing work here in America for Americans.
(nuts) The guy on the right is from the new administration in Washington. We are the guy on the left.
