Honest designer looking for an honest machinist with the ability to produce some custom parts in 7075 aluminum or 303 stainless (would like quotes for both).
I'm located in the Denver, Colorado area, but will accept quotes from anywhere (my last product was made in Arizona).
There are two different parts, looking for quotes on each. I have attached a PDF with renderings of the two parts.
Part #1:
The basics: start with 3/4" diameter rod, need two concentric holes drilled, some milling, and a drill and tap for 8x32 screw. Smooth finish. Finished size of the piece is approximately 0.750" diameter x 1.500" long.
Part #2:
The basics: Start with a 1.5"x1"1" block of metal, some milling, some drilling of concentric holes, and drill and tap for 8x32 screw. Smooth finish. Finished size of the piece is about 1.5"x1"x1"
If either of these sounds like something you could do, shoot me an email. I have a PDF of both designs I can send. When it comes time for fabrication I also have the AutoCAD file available (as .dwg or .dxf) so you don't need to recreate all the geometry.
Looking to have between 100 and 500 of each fabricated (please quote for each part, and in each material). Feel free to quote if you are only able to make one of the parts. If you would like the PDF's, PM or email me at:
[email protected]
I will be accepting quotes for a two week time period (9/1/09 - 9/15/09).
-Jason
JWfabrication
