586,795 active members*
2,806 visitors online*
    Feb 2005
    149
    I have all these little balls.
    I have a 16 x2 Isel ball and screw. Got some grit into the housing so it had to come apart!. So, is there an easy way to reload or wil I have to send it for repair?
    George
    24223
    There is a couple of previous links here on reloading, hopfully it has removable reload tubes.
    You should also check for two different size of balls used, it is often customary to use a smaller ball every other position, this is done to avoid jam up when operating.
    Al.
    Albert E.
  1. How many balls in nut?
    By phantomcow2 in forum Linear and Rotary Motion
    Last Post: 05-19-2019, 04:51 PM
  2. lost my balls
    By X2cnc in forum Benchtop Machines
    Last Post: 05-23-2009, 11:15 PM
  3. Help Me Get My Balls Back In
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 11-22-2007, 09:03 PM
  4. detent balls
    By norvil1 in forum MetalWork Discussion
    Last Post: 02-09-2007, 01:51 AM
  5. Ballnuts: Do you really need all the balls?
    By geohot in forum Linear and Rotary Motion
    Last Post: 12-27-2005, 07:34 AM
