586,271 active members*
2,994 visitors online*
Results 1 to 16 of 16
    Aug 2009
    9
    CNC Milling Machine: PWM Control Problem
    Hi there,
    I have a setup with MACH3 where it should send a PWM signal, which will be converted by a digispeed board into a 0-10V analogue signal for my motor drive, but all I am getting out of the digispeed board is 0.1V max.
    I've tried adjusting the attenuation trimpot on the digispeed board but it doesn't seem to do anything
    Does anyone know what could be wrong here?
    Just to be make sure I am testing the right thing, if the output from the digispeed board isn't connected to anything it should still send out the analogue signal, correct? I am just plugging my multimeter directly into the output on the digispeed board and getting the 0-0.1V readings.
    Thanks in advance,
    Phil
    Feb 2007
    4553
    Question
    What model breakout board do you have?
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2006
    357
    Don't have a digispeed but with a cnc4pc board the pulse width affects the voltage output, so you may want to take a look at that. I have mine at 5
    Aug 2009
    9
    jalessi: I have the C10 model board from CNC4PC.
    Gary: When you say your pulse width is 5 what do you mean? Is there a setting in MACH3 to control this?
    Feb 2007
    4553
    Post
    Do you have a instant messenger?
    Jeff...
    Feb 2007
    4553
    Question
    What model Digispeed do you have?
    Aug 2009
    9
    I have the digispeed DC-03.
    I have the digispeed connected just as it says in the user guide, with the 5V and GND from the breakout board and the PWM from the output pin assigned in MACH3. I'm also running the relays on the board to enable and set the direction of the spindle.
    I have windows messenger - [email protected] - but I won't be online for a while since its past midnight here and I'm about to go to bed.
    Aug 2005
    1095
    I just noticed this thread. Did you sort out your issues with the DC-03?
    Cheers,
    Peter.
    Homann Designs - http://www.homanndesigns.com/store
    Jun 2004
    6618
    There are lots of settings in Mach 3 that have an effect on spindle control. The manuals Peter has are pretty darn good though with screen shots. Can't get better than having Peter answer directly though.
    Lee
    Aug 2009
    9
    Yes I am still having trouble with the DC-03, although I am pretty new at this so I've probably just overlooked something really simple.
    At the moment the DC-03 shows the double flash (PWM mode) but I'm not getting the output voltage I need.
    I think my problem is probably in MACH3 but I can't seem to find what I've done wrong.
    Also here's my wiring setup for the DC-03 just in case I've done something really stupid here.
    Ana - none
    +5V - +5V from breakout board
    RL2 - CCW output from BoB
    RL1 - Enable from BoB
    Sig - Spindle Step from BoB
    Gnd - Common from BoB
    AV+ - none
    Vout - DC control voltage (should be +0-10V)
    AGnd - DC control voltage ground
    Relay outputs are connected to the switches in my motor controller
    Note: The relays are working fine, its just the speed control voltage that I'm having trouble with.
    Aug 2005
    1095
    Quote Originally Posted by phyllis_ave View Post
    Ana - none
    AV+ - none
    First thing to do is make sure that the DC-03 is in the correct mode. There are 2 jumpers (JP3)that set the mode.
    The status LED on the DC-03 indicates the mode that the DC-03 is in, when the unit is powered up.
    For PWM mode, the status LED will flash twice on powerup before going into the lazy double flash. The manual explains these modes.
    Also, have a look at this engineering not. It shows the position of the mode jumper for PWM mode.
    http://www.homanndesigns.com/EN009_V2.pdf
    The double lasy flash indicates that their is no PWM signal from Mach3 at the DC-03 'Sig' input.
    The manual also has a step by step Quick Start set-up guide. If you follow it, tell me at which point you can't get it to work.
    Cheers,
    Peter.
    Aug 2009
    9
    Ok I do get the double flash on startup then the lazy double flash after that. Also I have the JP1 jumper on the dc/dc side and I am not using the AV+ pin. Is this correct?
    It seems like there is some control coming from MACH3 as the voltage does change when I change the spindle speed, however it only varies from around 0-0.1V instead of the 0-10V that I should be getting.
    Aug 2005
    1095
    Presumably you have the DC/DC converter installed.
    Also JP2 selects whether you are using positive or negative pulses. You need to have this set to match what you have set up in Mach3.
    If you are only seeing the lazy double flash, then the microprocessor is not seeing a PWM waveform. That is where we need to concentrate. If the micro is not seeing the PWM, it won't produce a control voltage at the output.
    Cheers,
    Peter.
    Aug 2009
    9
    Isn't the DC/DC generator on the DC-03 board? Or is it a separate part that I don't have? Because if thats the case then I've found my problem...
    Should I just use the AV+ connection and move the JP1 jumper then?
    Also thanks for helping me out with this, its been driving me crazy for a while now.
    Aug 2005
    1095
    If you have an empty 8 pin dil IC socket in the middle of the board, then you don't have the dc/dc converter installed. In that case, yes move the jumper JP1 to the AV+ position and provide the AV power from your VFD
    Cheers,
    Peter.
    Aug 2009
    9
    Ah ok that'll do it. I knew it would be something stupid done on my part.
    Thanks so much for your help Peter, you're a lifesaver.
  1. Sodick EDM machine Model A7C with MARK XI Control - Start up problem
    By rajappa in forum EDM Discussion General Topics
    Last Post: 02-04-2021, 08:57 PM
  2. Help: Spindle Control in MACH3 - Milling Machine
    By phyllis_ave in forum Controller & Computer Solutions
    Last Post: 08-05-2009, 06:27 PM
  3. 640 M CONTROL MAZAK MILLING MACHINE
    By fenix728 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-27-2009, 12:24 AM
  4. About Engraving and Milling Machine Application Problem
    By kkk123 in forum Mach Software (ArtSoft software)
    Last Post: 07-29-2008, 02:22 AM
  5. Fanuc 15ma - Kafo milling machine problem!
    By F.Sharifi in forum Fanuc
    Last Post: 06-09-2007, 07:58 PM
