586,033 active members*
3,559 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Surfcam to robot code.
    Aug 2009
    Question Surfcam to robot code.
    Hi.
    Im woundering why my robot jumps frequently between the lines that i have been drawing in surfcam? Code problem?:withstupi
    example; if i have five lines and one circle. The robot draws a half circle and then begins to draw 3 hole lines, the it draws two half lines and then it dos the hole cirlce and then it finished the two "half lines".
    br
    Andy
    Jul 2007
    148
    Can you post some of the code here so we can see what might be going on?
    Try setting your sort type to none and gouge check to single. It's under the last tab.
  1. Surfcam cordinate to robot cordinate..
    By hride in forum Surfcam
    Last Post: 08-07-2009, 12:45 PM
  2. Looking for Robot Auto Palletising (Panarobo and or STORK Robot)
    By rsarwanto in forum European Club House
    Last Post: 09-12-2008, 12:22 PM
  3. CRS Robot Arm
    By pestana1957 in forum RC Robotics and Autonomous Robots
    Last Post: 01-26-2007, 09:04 PM
  4. inventor 3d solid to surfcam g code
    By villiersterrace in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-24-2006, 12:23 AM
  5. inventor 3d solid to surfcam g code
    By villiersterrace in forum Autodesk
    Last Post: 08-09-2006, 11:25 PM
