586,060 active members*
4,328 visitors online*
    Slave an axis?
    Does EMC2 let you slave an axis to drive both sides of a gantry? A search shows this has been asked before, but didn't seem to get answered. Thanks.
    Mar 2006
    427
    Gerry, I am not infront of the machine right now to test this but I believe when you are setting the pins you can make more than one pin be the x axis. This is the screen that I am talking about.
  1. Slave axis problem
    By Curtis Erpeldin in forum DIY CNC Router Table Machines
    Last Post: 07-30-2008, 08:57 AM
  2. backlash compensation with slave axis
    By jeb in forum Mach Software (ArtSoft software)
    Last Post: 03-04-2008, 09:05 PM
  3. Slave axis
    By CARLES in forum Mach Software (ArtSoft software)
    Last Post: 01-11-2007, 07:17 PM
  4. Need to slave slave A axis to B axis..
    By foam27 in forum Mach Mill
    Last Post: 07-04-2006, 03:58 AM
  5. Slave axis
    By walter in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2006, 01:47 AM
