586,077 active members*
3,767 visitors online*
Thread: text height
    Aug 2004
    36
    text height
    Can some one help me with the following NC program?
    I first drew it in Millwrite 2000 sent to floppy then opened in Mach2 I am able to engrave it but it is inverted starts on the left –Y cuts the text to the right + Y with the top of text facing the + x direction. It used to start on the y + side and cut towards the –Y side with the top of text towards the – x direction? The second thing it is doing is I set the text height to .500” tall it engraves at .130” tall. So I made a new file set the text height to .750” and then it cut only about .200” tall? It is probably something very easy.
    Thanks Clint
    O1111;PUT YOUR PROGRAM NUMBER HERE
    G80G40G17
    M06T1
    G90
    M03S5000F15.0
    M08
    G00X0.3971Y0.5026
    G00Z0.05
    G01Z-0.0087F6.
    G03X0.3266Y0.5668I-0.1393J-0.0821F15.
    G03X0.1452Y0.5556I-0.0805J-0.171
    G03X0.0411Y0.4315I0.1422J-0.225
    G03X0.0542Y0.1423I0.3184J-0.1305
    G03X0.1602Y0.0369I0.2181J0.1134
    G03X0.3173Y0.0245I0.0935J0.1825
    G03X0.4127Y0.1124I-0.0483J0.1481
    G00Z0.05
    G00X0.6408Y0.0175
    G01Z-0.0087F6.
    G01Y0.5825F15.
    G00Z0.05
    G00Y0.0175
    G00X0.887
    G01Z-0.0087F6.
    G01Y0.403F15.
    G00Z0.05
    G00X0.8701Y0.5656
    G01Z-0.0087F6.
    G03X0.8701Y0.5995I0.J0.017F15.
    G03X0.8701Y0.5656I0.J-0.017
    G00Z0.05
    G00X1.1072Y0.0175
    G01Z-0.0087F6.
    G01Y0.4097F15.
    G00Z0.05
    G00Y0.3459
    G01Z-0.0087F6.
    G02X1.2029Y0.3985I0.1109J-0.0882F15.
    G02X1.3984Y0.223I0.0189J-0.1756
    G01Y0.0175
    G00Z0.05
    G00X1.5693Y0.413
    G01Z-0.0087F6.
    G01X1.7086F15.
    G00Z0.05
    G00X1.6295Y0.5825
    G01Z-0.0087F6.
    G01Y0.1005F15.
    G03X1.7094Y0.0175I0.0831J0.
    G00Z0.05
    M30
    Aug 2004
    36
    Text height
    I figured it out I had my steps per unit set to 2000 in Mach2 then I wound up setting it to 8000 to get it to engrave the same size as what was drawn. Now I need to figure out why it engraves its way to the begining of the text. then it raises up from cutting each letter.
    Thanks Clint
  1. AutoCad Text
    By CNCRob in forum Autodesk
    Last Post: 04-04-2013, 04:09 PM
  2. single line fonts?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 02-18-2006, 06:51 PM
  3. Software, Z-axis - Graphics vs. Text
    By WadeConner in forum DIY CNC Router Table Machines
    Last Post: 03-22-2004, 02:56 PM
  4. Tool Height Offsets
    By JamesBond in forum DNC Problems and Solutions
    Last Post: 06-01-2003, 08:01 PM
