586,058 active members*
4,575 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > help with micro stepping
    Feb 2005
    121
    hello im running my board in eighth step mode with a 1.8 deg steppers ie 200 steps for 360 deg ??? but according to the stepping sequence chart that came with the xylotex board its 33 stepps for 360 deg?? so im trying to find out steppes per inch for the contrallor software i have xyoltex board in eighth mode pac scince steppers 1.8 deg in bi pollar and 1/4-20 lead screws is i use the 200 number it 4000 stepes per inch and if i use the 33 number its 660 thats a big diffrance any help pls thx chris
    66
    Disregard the chart,,,, It fdoesn't make sense to me either, I'm sure it does to the others. But lets get you going. Running in 1/8 steps means that it will take 8 microsteps to equal one full step, Your motor takes 200 full steps to make one revolution,,,, multiply by 8 you get 1600,,, You are using 1'4-20 rod, so you need 20 revolutions to travel one inch,,,, 1600 times 20 is 32000. Punch that into your software, and see what you get.
  1. harbor freight micro mill
    By gearcut in forum Benchtop Machines
    Last Post: 02-18-2010, 09:24 PM
  2. Need help Japan Servo Stepping motor ?P-86sv2-003 data?
    By jlagran he in forum Stepper Motors / Drives
    Last Post: 12-15-2004, 09:36 AM
  3. New to Mill and CNC - Can you mix a Mini and Micro Mill
    By Sherpa in forum Benchtop Machines
    Last Post: 09-09-2004, 03:36 PM
  4. Harbor freight micro mill?
    By Lizard2033 in forum Benchtop Machines
    Last Post: 06-26-2004, 01:04 AM
  5. Concidering micro stepping?
    By lsfoils in forum CNC Machine Related Electronics
    Last Post: 03-27-2004, 05:36 PM
