586,647 active members*
2,253 visitors online*
Results 1 to 7 of 7
    128
    gnome sized Gibson LP top w/video :)
    Just messing around with my router... this is the second time I've let the chips fly.
    This is a gnome-sized Gibson LP ripped out of some scrap wood I had laying around. not sure if the coarseness is my cnc, the feedrate, or the crappy ryobi 1/4 slotting it I used. seemed to clean up OK after I hit it with some 220 grit.
    [ame="http://www.youtube.com/watch?v=N9LosKTEXxU"]YouTube - CNC Routing Gibson LP 'scrap wood' top[/ame]
    Check out some of my vids: http://www.youtube.com/user/blauschuh
    May 2006
    41
    Looks good, might want to try a ball and bit for the carving, with a low step over (10% of the bit diameter) you wouldn.t get the stairstepping. If you dont mind me asking, where did you get the file you used for the machining, i have been looking for a les paul file myself. I am probably gonna chip into the Les Paul digitizing effort, but really would like to see a sample of the scans before committing.
    Apr 2007
    8082
    Use a harder wood with finer grain (like hard maple) and you will see much cleaner cuts. Pine and spruce are soft and it's hard to get clean edges.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    128
    Quote Originally Posted by zigmart View Post
    Im going to be ordering a bunch of bits this week....
    i have a full LP body .3dm file. PM me....
    Quote Originally Posted by CarveOne View Post
    CarveOne
    Thanks, I figured that. this was just a scrap i had laying around... i just hit it with some 220 grit and knocked the edges down and it looks good. One thing i noticed is that down one side everything is great, then as the bit travels up the other side there is some tear out. this is literally like a $3 router bit tho.
    Apr 2007
    8082
    Quote Originally Posted by margni74 View Post
    That's a normal effect. The grain structure is effecting how the cutter is digging into the wood. Resin rings are harder than the softer rings in pine and the woods with less pronounced hardness changes will machine more consistently. The harder the wood the less tear out you will see. It takes higher rpms and really sharp edges with ideal flute pitch angle to cut soft woods with minimal tear out. Feed rate is more critical also.
    CarveOne
    CarveOne
    Apr 2007
    1955
    Nice work. I am just wondering if you mean that you are sometimes cutting - to the right and then other times - to the left. Routers cut best in one direction - the direction of the arrow.
    If you "climb mill", at least manually, it tends to make a different sort of cut finish, at least for me.
    Apr 2007
    8082
    Quote Originally Posted by harryn View Post
    Yes, that's a big part of it. In wood it's compounded by the wood grain structure that metals don't have. Also, when the cutter edges gets loaded with wood resin it increases the tear out by grabbing the softer fibers and pulling it out. Once the resin burns onto the cutter edges it starts wearing its way through the wood more than cutting it.
    CarveOne
    CarveOne
  1. where can i buy spindles for diy sized machines
    By compositepro in forum DIY CNC Router Table Machines
    Last Post: 05-13-2006, 02:17 AM
  2. How to Ream an odd(?) sized hole
    By MikeLMR in forum MetalWork Discussion
    Last Post: 08-31-2004, 02:09 AM
