586,075 active members*
3,982 visitors online*
    Mar 2008
    175
    One clean up pass after threading…T32B
    After single point external threading some 6061 M10x1.5 pieces I was taking one pass with a OD tool to clean up the OD and then wanting to take one more pass with the threading tool to clean up the remaining burrs from the threaded area.
    Added another threading process with the start and finish X .001” above the root diameter and set thread height to .0005”. The least amount of passes it would take was 5 regardless of any combination of start height or thread height.
    On another control it has a feature to run one pass at the finish depth after the OD clean up. Is there a simple way in Mazatrol to set up one pass at the finish depth or if I use a manual program using IPR will it pick up the thread start point?
    Edit/Delete Message
    Mar 2008
    638
    Check parameter U55. That is the # of finish passes. If I set it to 0 or 1, it will thake one finish pass. I can set my # of (regular) passes to a minimum of 3. Any less and it alarms out. It makes 3 passes with those settings. I too would be interested in bringing it down to 1.
    Mar 2008
    175
    U55 is set to 0, I did get it down to 3 but that's the best it will do.
  1. Mazak QT-8 with a T32B controller need help
    By Captdave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-18-2011, 04:18 PM
  2. Each pass different than the previous
    By gage1049 in forum DIY CNC Router Table Machines
    Last Post: 10-22-2008, 09:47 AM
  3. Heidenhain pass
    By inioxos in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-09-2007, 07:00 PM
  4. QT8/T32B Control
    By lovell110 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-01-2007, 01:26 AM
  5. Can I run axes at different ipm on the same pass?
    By yorttroy in forum DIY CNC Router Table Machines
    Last Post: 01-04-2006, 07:34 PM
