586,094 active members*
3,709 visitors online*
    128
    Determining Latency...Which #?
    I'm going back over the numbers in my configuration and noticed my "Latency test result" was set to 24000ns. I re ran latency-test a couple of times with about 30 glxgears running in the background as well as firefox in the background...
    Here are the numbers ... first just running glxgears and then adding in a firefox along with glxgears.
    Which number is the latency test result, the servo or base thread max jitter?
    Check out some of my vids: http://www.youtube.com/user/blauschuh
    Mar 2008
    267
    Nice motherboard.
    What is it?
    Oh and Yes use the base thread latency in Your case 12379.
    128
    Quote Originally Posted by Zig View Post
    Nice motherboard.
    What is it?
    It's an old Asus board (something like a 1.2GHz AMD processor... so old I don't even remember the model!
    Sep 2007
    200
    try playing some music just to be sure
    the skip button puts my base thread up to about 30,000
    Aug 2005
    180
    Nice results. Be careful try opening / closing windows, running with networks connected updating software etc. you may see a periodic jump in latency value which will translate in to a following error when machining. Also when setting your base period give yourself a bit of headroom. My system works well and consistently with a period of 30000ns.
  1. Improving my latency figures
    By greybeard in forum LinuxCNC (formerly EMC2)
    Last Post: 07-23-2009, 08:30 PM
  2. Help determining latency and EMC timing parameters....
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-05-2008, 11:05 PM
  3. EMC2 latency from Network card
    By randyf1965 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-23-2008, 04:08 AM
  4. Latency, Jitters & Lost Steps
    By Imagineering in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-22-2005, 01:39 PM
  5. Determining VA load
    By Swede in forum CNC Machine Related Electronics
    Last Post: 04-10-2004, 10:00 PM
