586,114 active members*
3,337 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > problem with ncstudio and cnc router
Page 1 of 3 123
Results 1 to 20 of 57
    Sep 2009
    hello
    i have here now a cnc router from china
    but it is not working.
    i have install the software from nc studio i think at the good way.
    I installed the software and it found the pci card correctly.
    I turned on the cnc and then opened the ncstudio software, once i did that the X-Y-Z Axis started to move by them selfs.
    when they reached the limit switch's they still continued and started to make a grinding noise so i tund off the main power to the cnc.
    when i looked at the software it had an error "limit switch on".
    so i think i have bad version of ncstudio
    please help me with this
    thanks
    andre
    Jan 2006
    19
    Andre, what version nc-studio do you have !!
    what model machine and company you get it from !
    Aug 2009
    44
    Dear andre,
    i think the parameter you set is not right, what is size of the machine?
    lele
    www.cncrouter.cn
    Nov 2009
    314
    NCStudio ANSER
    Bro,
    I think the card doesn't match the software version.
    Mike
    Nov 2009
    Same problem happened to me with my Chinese cnc machine. However, After I received a newer version of the software from the seller which was NCStudio V5.5.60 , My machine worked as expected and I was able to control it the way I like.
    Nov 2009
    314
    Andre,
    wish your problem was solved here!
    I have Ncstudio V5.5.60 ENGLISH Setup version,any one who has these series question,just email me.
    Mike
    [email protected]
    Sep 2019
    5
    Re: problem with ncstudio and cnc router
    Hello distinct,
    I have bought new ncstudio card but they didn't give me any software. when i asked them they gave me software version 5.4.49 which is in chinese language and i tried to contact them again. they didn't reply. can you please help me with the software. my card runs on version 5.4.49/5.5.55/5.5.60.
    The problem that i am facing right now is i cant move any axis in the cnc machine from nc studio software. I don't know why the software is not working because i have done all the connections as they have said.
    hi ? if connection is ok. then check about the parameters in software.
    Oct 2020
    Arrow Re: problem with ncstudio and cnc router
    Quote Originally Posted by distinct View Post
    Dears, I have exactly the same problem. Could you please provide me the right version of Ncstudio 5.5.60? I have asked Weihong directly, but they only want to sell latest version ...
    Dec 2009
    Questions about CNC Router
    Quote Originally Posted by EXLASer View Post
    Bro,
    Mike
    HI Mr MIke:
    The problem is that when I started the work with the software « NC Studio » At 0,0 In the screen it apperas 0.0 but in the table of work I notice that It shifted to (0.5 ; 1.3) Or (1.75 ; 0.2) there is no equiliberieum between the screen and the machine Is there any suggestion to solve that problem ?
    Best regards
    Nov 2009
    314
    Smile
    Quote Originally Posted by Petr View Post
    HI Mr MIke:
    Best regards
    Hello Petr,
    Please see attachment pictures,
    as you saved M.Coor. not W.Coor.
    E.g. we set M.Coor.(X40.653 Y65.662 Z7.494),
    Now You need to read and back to the worpiece coordinate(W.Coor.),
    Rgs
    Mike
    May 2017
    23
    Angry Re: problem with ncstudio and cnc router
    Hi.
    I live a real nightmare. I use a 1325 standard chinese cnc machine with a 5.5kw spindle. Z axis loses steps all the time , mainly after changing a bit.
    These are my parameters. Can you help me ?
    Nov 2009
    314
    Hi Muhammad,
    I received your message and had sent you "NC studio Version V5.5.60 ENGLISH Setup version " through my email,have you got it???
    Please download that software(3.7M).
    If any unclear please don't hesitate to let me know,
    Best Regards
    Mike Wang
    [email protected]
    www.xyz-tech.com
    Dear Sir,
    How are you. Hope you will be fine and doing good. Sir I have the same problem as discussed in CNCZONE.com. Which stated that
    (((I have here now a cnc router from china
    please help me with this))))))
    So sir kindly u can send me the NC studio Version V5.5.60 ENGLISH Setup version . It will be so kind of you. I am worried from last 4 months. Thanks In Advance.
    Mr. Muhammad Farhan
    Dec 2006
    878
    Question NC Studio? Piece of Crap or just Misunderstood?
    Seems to be used on the cheap Chinese machines.
    So which is it?
    We see posts from Newbies from time to time complaining that NC Studio does not work.
    What is the story? A cheap POS or just Misunderstood?
    Any users out there with an opinion?
    Rocket.
    Nov 2007
    2466
    rocket i got to help a guy here in the states who had nc studio and it is a impressive controller, as usual there is no real manual so setting it up and using it is a piass but if the chine get it together the nc has hope
    jim mcgrew
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Oct 2010
    Unhappy help plz experts !
    Hi everybody !
    I have just bought a cnc router mashine with table size 6090 from a chinese company. I have installed the Ncstudio program and afterwards moved the 3 axis in different parts with no logical limits.next day the mashine didn't move anywere i tried so many times but invain !
    by the way , every thing is colored red, I mean all limits.would anyone please help me to solve that problem plz soon
    Feb 2009
    23
    Cool
    Welcome to club of the chinese nightmare.From experience the only person who can help is MR SHAKEEL AHMED.You will find his detail in the forum.But untill he reply check the settings of table.Let me know what are your settings in both Machining and Manufactory(password is NCSTUDIO).
    Regards
    Jul 2010
    Chinese 6090 MAchine
    @ marqcnc, You've bought a IEKH machine?
    One of my friends had the same problem. Are you sure you've set the right settings (like enc steps) etc. With the machine of my friend they didn't. I had o figure it all out for him. If you have the IEKH machine, I attached some info which could be helpfull.
    Also, make sure the cable of the PC to the machine is well attached, I found some problems with it before. But ofcourse, if all of the limits are red...?
    Last: in the (I think) third menu all to the bottom is something like "overide limits" when you click it it will open a window. As long as you keep this window opened, it ignores the limit switches.
    Good luck with it! I hope you get better Chinese support then we did
    Attached Files Attached Files
    Sep 2019
    5
    Re: help plz experts !
    Hello marqcnc,
    I have the similar problem where i can't move any axis. i have bought the cnc from china and card is brand new and software version is 5.4.49 but i couldn't move any axis. What i have to do plese help me
    Nov 2009
    314
    Grzegorz ,I sent Ncstudio just now,please check your email.
    And Thank you for your Christmas letter,you can take our machine's quotation for reference,
    Very pleased to help you!
    Hello!
    I was reading the CNC forum looking for the NCStudio for my 6090 machine, and found that You are able to be so kind and send the upgraded version 5.5.60...
    It could be a very nice Christmas gift
    BTW, I've checked your site, and it looks interesting - could you provide more details about the smaller machines you provide? Some catalogue together with aproximate pricing?
    Sincerely
    Grzegorz Koslacz
    Warsaw
    Poland
Page 1 of 3 123
  1. problems Chinise Router NcStudio
    By frad8 in forum Chinese Machines
    Last Post: 05-31-2021, 08:34 PM
  2. Problem importing ArtCam Pro file to NCstudio
    By dancingdragon in forum ArtCam Pro
    Last Post: 02-28-2016, 08:43 PM
  3. Configure NCStudio for JX-6090 CNC router from China
    By julien123 in forum Uncategorised CAM Discussion
    Last Post: 06-12-2014, 11:51 PM
  4. Problem with NCstudio for cnc router
    By dareformore in forum Commercial CNC Wood Routers
    Last Post: 03-13-2012, 08:19 AM
