Any thoughts on this design from all you guru's ?
Will be using Mechmate home ground rails for x and y. The results some of those guys get are amazing (see mechmates forum for some amazing router builds) . rack and pinion of x and y. Will have a water table that can be wheeled in and out. Would also like to use it ocasionally as a router, I appreciate that there will be a fair amount of set up time to convert between the two. Will be using a gear a belt reduction on all axis approx 3:1.
Havent even thought about z yet but it will have THC. Any thoughts here would be greatfully received.
I have a candcnc plas pak 1a kit. Want to have it running by end of december latest.
All advice much appreciated.
