586,082 active members*
3,613 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > MC-5VA ...???Need good idea!!!
Results 1 to 6 of 6
    Aug 2009
    4
    Question MC-5VA ...???Need good idea!!!
    Wep!!! i have this Alarm since i buy this Machine...When i press stop or M5 this NICE machine shut down whit this Alarm 109 SPINDLE DRIVE UNIT..NICE!!!!!! I called thechnicien ..after 3 hours he toll me the try new power supply 550v(transfo)..but still not working!!!...now the spindel wont start!!i change the tap...480 to 440 now she start again but still don`t want stop..i dont now..!!.i dont now.!!...all voltage is in the range.. R.S.T terminal.????..i have all books for this Machine....
    thank....for your Help!!!
    english is my second language....
    Apr 2009
    1262
    Scotty, give me that power!
    I've seen this before on machines and the main reason was inadequate power supplied to the machine. The voltage checked OK and the machine powered up fine, but the spindle start/stop would cause an alarm. It turned out that the cable to the machine was undersized and too long which caused a large voltage drop when the machine demanded large current draws.
    However if the cable and supply are strong, you maybe have a drive unit issue. Check your drive unit for specific alarm codes and look in your drive unit manuals for the suggested fix based on the code.:idea:
    Feb 2009
    6028
    MC5
    What spindle drive/control is it. VAC-A or DC, or Fanuc?
    Aug 2009
    4
    Quote Originally Posted by OkumaWiz View Post
    Thank you!!i will check my cable, is in alluminium , it`s maby the problem?
    thank again!!!!
    Aug 2009
    4
    Quote Originally Posted by underthetire View Post
    the control is VAC-A...Her!!!
    Feb 2009
    6028
    MC5VA
    Then yes, it could be an impedance problem. Too much resistance through the power cable/transformer will not let the drive regenerate through the line. Okuma's were sensitive to this up to the new "book" style drive units. All the VAC type drives did this.
  1. Replies: 0
    Last Post: 04-18-2008, 03:09 PM
  2. Is it a good idea to?
    By SPEEDRE in forum Benchtop Machines
    Last Post: 08-23-2006, 02:49 AM
  3. Using X-Channel For Rails Good or Bad Idea?
    By meat in forum DIY CNC Router Table Machines
    Last Post: 02-16-2006, 05:59 AM
  4. New idea!
    By smitty in forum OneCNC
    Last Post: 08-26-2003, 04:45 PM
