586,219 active members*
3,151 visitors online*
IndustryArena Forum > CAM Software > CamWorks > TECH DB will not save speeds and feeds
    Sep 2009
    20
    I am having a problem with my tech db as far as saving speeds and feeds per too. Some tools save no problem (face mills) while others like my drills save sometimes but my mills never. I am doing everything the same but i dont know what else is happining. Does anyone else have this problem?
    thanks
    adam
    Aug 2005
    249
    CAMWorks is still in the R&D phase. There is so many items that are not right. We have been telling GT about issues but they never seem to look at them. It is very sad. Mine will not save tool lists. The reamer page displays the same reamers all the way down the page until one scrolls to the bottom and then back to the top. The tools data base is all out of whack as the fields do not fit the text. Even if I change the fields to fit when I access the data base again they are back to the way they were. The list goes on. Sorry I cannot offer any positive feed back to your issue.
    Jeff Lange
    Lightning Tool & Manufacturing, Inc.
    Apr 2005
    88
    I dont know if you have checked this, but do you have read and write access to the folder annd to the mdb file?
    Sep 2009
    20
    Yes i do
  1. Speeds and feeds (I know, I know)
    By mrcodewiz in forum Benchtop Machines
    Last Post: 10-18-2008, 09:00 AM
  2. Help! with Feeds and speeds please!
    By sjotime! in forum Visual Mill
    Last Post: 02-13-2008, 07:56 AM
  3. Speeds and Feeds
    By wdp67 in forum Benchtop Machines
    Last Post: 07-10-2007, 08:06 AM
  4. feeds and speeds
    By rchprks in forum MetalWork Discussion
    Last Post: 07-18-2006, 12:48 AM
  5. Speeds and feeds
    By Hack in forum MetalWork Discussion
    Last Post: 10-15-2005, 04:47 PM
