586,094 active members*
3,946 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > I want that mirror finish
    May 2009
    33
    Ive been face milling this block of aluminum all day trying to get a mirrored finish and im not making progress. Im working on our manifolds and the ones we used to buy had a nice, smooth, mirrored finish and i cant make it happen. right now im using a 2 in. 3 flute indexible face mill and have run anywhere from 1500 rpm to 5000 rpm along with different feed rates and no luck. Are there special face mills for aluminum? where can i find them?
    Jan 2006
    4396
    Quote Originally Posted by CORBIN92087 View Post
    Use Polished Inserts (I Like Cermit) with a .03 Radius.
    Feeds and Speeds will vary depending on the set-up and machine rigidity
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2008
    443
    PCD (PolyCrystalline Diamond) and very high speed is the best assurance of results. It is NOT cheap to tool up, but it is something you only buy once and never look back.
    I have a friend who bought one of these in a 3" 6-insert version. He went from running a 3-insert carbide face mill at 45 inches per minute to running this one at 225 inches per minute. The surface finish went from a 24~32 Ra range to 4~6Ra. With a wiper insert, he could be getting a 2!
    http://valenite.com/internet/4558/In.../vflashcat.pdf
    Mar 2006
    2712
    PixMan mentioned the magic word, WIPER. It will actually burnish the surface.
    Dick Z
    DZASTR
  1. Mirror finish steel and aluminum parts vibratory bowl?
    By Toggle in forum Material Machining Solutions
    Last Post: 10-18-2018, 10:14 AM
  2. Mirror finish on Aluminum?
    By RP Designs in forum MetalWork Discussion
    Last Post: 09-11-2009, 11:05 PM
  3. mirror image
    By cp465vw in forum Machines running Mach Software
    Last Post: 04-14-2009, 04:39 AM
  4. Zinc-Plated Finish vs plain finish for threaded rod?
    By Almaz in forum DIY CNC Router Table Machines
    Last Post: 10-21-2008, 08:39 PM
  5. Mirror - is this a bug?
    By LongRat in forum SheetCam
    Last Post: 10-11-2007, 06:48 PM
