586,094 active members*
4,112 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 setup question.
    Feb 2009
    187
    I am new to this fascinating world of CNC. I am slowly working at bring another X2 mill into the world of CNC and I have a question on the current set resistor size for a G540 drive. I am using a Keling motor # KL23H2100-35-4B which is rated at 3.5 amp. PEr the documentation I see that the resistor is sized by using 1K ohm per amp of motor rating. I can't find 3.5 k resistors locally. I do have 3.3k resistors in my surplus parts drawers. Is it a wise decision to install these resistors that I have and run a little on the conservative side or should I continue to look for 3.5k? Also what would I loose performance wise by using the 3.3k resistors?
    Thanks in advance.
    RWW
    Quote Originally Posted by whitehedr View Post
    Thanks in advance.
    RWW
    3.3/3.5 = 94.2% of the torque you'd have at 3.5 amps, so you lose about 5%.
    Jan 2008
    932
    I couldn't find 3.5K either, so I just used two resistors that totaled 3.5K ...
  1. G540 and EMC2, need help with setup
    By rogerer in forum Gecko Drives
    Last Post: 05-16-2009, 07:21 PM
  2. g540 question
    By chrisw765 in forum Gecko Drives
    Last Post: 04-09-2009, 04:35 PM
  3. trouble with setup of g540 and mach
    By ZNAK in forum Mach Software (ArtSoft software)
    Last Post: 04-05-2009, 02:56 PM
  4. G540 microstepping motor setup
    By mikie in forum Gecko Drives
    Last Post: 03-19-2009, 12:15 AM
  5. g540 setup question
    By don_don in forum Gecko Drives
    Last Post: 02-16-2009, 09:05 PM
