586,121 active members*
3,061 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > taper pipe thread milling
Results 1 to 6 of 6
    Jan 2006
    17
    Is it possible to thread mill taper pipe threads?
    Oct 2007
    30
    Smile
    Heavy Metal:
    Yes it is possible. Both Exterior and Interior NPT threads. I am not sure what size you want to do, nor do I know what type of threadmill that you have access to, but this is an example of a 2"-11 1/2 I.D NPT thread using a 5/8 diameter shank threadmill, with .82 cutting dia. The insert is a 21mm height -11 1/2 pitch , 4.7mm thick, and 12mm from back of insert to end of teeth . (The insert is specific to the pitch of thread.) So if you have a single point, this would not work for you. But single point thread milling can be done as well with some modification.
    O1234
    (X=0,Y=0 ORIGIN)
    (NO TOOL RADIUS COMPENSATION D1=0)
    T1M6
    G90G0G54G17G43H1X0.Y0.Z1.9685S2338M3
    G1Z-0.7674F196.9 M08
    G91G01G41D1X0.3747Y-0.3747F6.6
    G3X0.3747Y0.3747Z.0109I0.J0.37468F4.3
    G3X-0.7494Y0.7500Z.0217I-0.75004J0.
    G3X-0.7507Y-0.7500Z.0217I0.J-0.75071
    G3X0.7507Y-0.7514Z.0217I0.75139J0.
    G3X0.7521Y0.7514Z.0217I0.J.75207
    G3X-0.3760Y0.3760Z.0109I-0.37603J0.
    G1G40X-0.3760Y-0.3760F196.9
    G1Z0.6739
    G90X0.Y0.Z1.9685
    M30
    ***I HAVE A PROGRAM YOU CAN USE TO THREADMILL ANY ID/OD THREAD GIVEN FROM A MANUFACTURER & DEALER OF THREADING INSERTS & TOOLS. I USE THEM ALL THE TIME. IT HAS A POST PROCESSER BUILT IN TO POST YOUR PROGRAM, SO JUST FOLLOW THE WIZARD AND CUT YOUR THREAD! I SENT IT TO YOUR PM.
    Oct 2007
    30
    Thread Mill Post Software
    See link below.....
    http://www.carmex.com/downloads.php?instance_id=18
    Left side of page, where it says Mill-Thread software.... click here, download and enjoy.
    Jan 2006
    2985
    You can also use an NPT thread mill.
    http://www.kodiakcuttingtools.com/Th...T-Threads+242/
    Matt
    Nov 2005
    160
    Yep, I got my pipethread mills from Frank at Maritool. I use them for larger pipe threads because I didn't spring for the gearbox. Thread milling is why I didn't bother with it.
    Feb 2008
    12
    HI,
    JUST BROWSING AROUND AND SEE THAT YOU HAVE A TAPER THREaD MMILLING PROGRAM.WOULD YOU SHARE THIS WITH ME OR TELL ME WHERE I CAN GET IT
    THANK YOU
    [email protected]
  1. NPT Taper-to-Straight-to-NPT-Taper Thread
    By bdyenter in forum MetalWork Discussion
    Last Post: 09-16-2009, 02:10 PM
  2. 1/4-18 PIPE THREAD
    By Get lucky in forum G-Code Programing
    Last Post: 02-04-2009, 12:45 PM
  3. Thread Milling a Taper
    By automizer in forum G-Code Programing
    Last Post: 06-13-2008, 04:23 AM
  4. Help with converting the tapping data to American taper pipe.
    By custer in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-15-2007, 03:28 AM
  5. Pipe Thread
    By harley88 in forum Haas Mills
    Last Post: 11-29-2005, 05:43 PM
